Air filter
Old Dec 5, 2007 | 05:00 AM
zss42002's Avatar
zss42002
ok so should i check the actual filter or just go by the minder? should i change it sooner than the minder or will it hurt anything if i change it every 3 or 4 oil change??
Old Dec 5, 2007 | 12:47 PM
blackhat620's Avatar
blackhat620
There is no way to check the filter by looking at it. Just go by the filter minder. Filter minders have been used by off road & heavy equipment for years very successfully. Filter minders measure vacuum resistance.
You can change your filter element sooner, but you are just hurting your pocket book as the filter is about $55 each.
Check out these links for a little more info.
http://www.donaldson.com/en/engine/s...ary/001220.pdf
www.filterminder.com/
brother steve
6.7L Power Stroke Diesel
15
Oct 29, 2015 02:24 PM
fordtruck661
Oct 22, 2011 08:44 PM
copasspupil
Nov 26, 2009 02:03 PM
RichardinAtlanta
Nov 22, 2006 09:17 AM
NorthCarolinaExpy
Nov 12, 2005 11:59 AM
