Front disc brakes
Old Nov 15, 2007 | 10:03 PM
rogue40's Avatar
rogue40
Originally Posted by bliss1
that would be great, but that bolt does not line up with anything and if in the right position it will bind. any ways another ? wasn't paying attention when i took out the king pins(wich could be part of stop problem) does the bearing that comes with the king pin kit go under or over the axle. i put it back together under the axle. it looks right, but want to make sure.
It goes under and supports the weight of that quarter. You have it right.
The shims go on top to take up the slop that allows the spindle to slide up and down on the king pin.
Old Nov 16, 2007 | 09:13 AM
bliss1's Avatar
bliss1
thanks. i thought it should carry the weight, but most manuals ddidn't even show the bearing.
Old Nov 16, 2007 | 09:44 AM
Roger Carter's Avatar
Roger Carter
I have put '73-'79 power disc brakes on a few '65-'66 F-series trucks. I have always used ALL the pieces from the donor truck. The only exception is the radius arm bushings. The bushings should be for the '65-'66, due to the different frame brackets. Found this to work the best. Not saying there aren't other ways to acheive the same results.
Other than being dirty, heavy, messy and greasy, the job is a snap...and worth the effort.
Good luck.
Roger Carter
Old Nov 16, 2007 | 03:53 PM
Customcab's Avatar
Customcab
When are you guys traveling my way to assist me installing a 73 F100 front disc into my 65 with all drums. Thanks Bigblock for the pic's in your gallery; I was questioning the brake stop bracket;
Also I assume reverse light indicator isn't a problem when using a 79 below set up?
Mitch
Old Nov 16, 2007 | 04:39 PM
jowilker's Avatar
jowilker
Mitch
What ya planning for Thanksgiving?
John
Old Nov 16, 2007 | 06:08 PM
Retiredfire's Avatar
Retiredfire
Big block I can find pictures of the front in
Old Nov 16, 2007 | 08:03 PM
rogue40's Avatar
rogue40
Mitch
How's the weather in TN about now?
I've been jonesing for a Harley ride!
Old Nov 16, 2007 | 08:29 PM
daveengelson's Avatar
daveengelson
Completed the upgrade when came across this article posted by another member.
http://www.mongrelmotorsports.homest...f100discs.html
The next best upgrade is the power steering.
dave
Old Nov 16, 2007 | 08:41 PM
bigblockford_390's Avatar
bigblockford_390
What would you like pictures of? Let me know and I can see what I can come up with.
Jeff
Old Nov 16, 2007 | 09:33 PM
Customcab's Avatar
Customcab
Unfortunatley; I'm working on Thanksgiving; but the weather here is fine; never to cold for Ford Truck Fanatic's. I've been gathering and reading all the info on doing this swap; got the donor which is the first step from a local FTE buddy; he's currently in hospital with back surgery; once well we'll pull the parts for a disc swap. But hey if your ever in my area; your always welcome to turn wrenches...
Mitch
Old Nov 17, 2007 | 08:28 PM
Retiredfire
big block Iguess I was looking for pictures of the disc swap
Old Nov 17, 2007 | 11:19 PM
bigblockford_390
I have posted some pictures of my swap in my gallery. If you would like some other pictures let me know and I can see if I can get them.
Jeff
leftturndave
Apr 18, 2010 11:11 PM
luis2171
May 28, 2006 11:31 PM
avery
Jul 7, 2003 05:23 AM
jskinsey
May 9, 2002 06:12 AM
