power steering up-grade
Old Nov 18, 2007 | 11:02 AM
heavy d460's Avatar
heavy d460
Hey guys... I've been told by a couple of local Ford gurus that the power steering out of a 80-82 Datsun King Kab is pretty much a direct bolt in (very little mod.). Does anyone out ther have any expeirience with this swap. This swap is for 63-75 F-100. Mine is a 61 M-100 uni. Any suggestions are greatly appreciated.
Old Nov 18, 2007 | 01:07 PM
FordBoypete's Avatar
FordBoypete
Exclamation
Since you don't say, I presume you are talking about a 2Wd 61 Merc.
If you have a 1957 thru 1964 style chassis w/ single I beam front suspension & 4 leaf springs then your GuRus are Partially right, except if I'm not mistaken it's a Toyota P/S box that is adaptable, not a Datsun (aka Nissan) King Cab which others used. There are articles and posts here in the FTE Archives on that.
Since twin I beam set up uses completely different chassis & suspension the GuRus are absolutely wrong about their statement 1963 to 1975. It should instead read, . . . . . 1961 thru 1964.
Frame styles used on F&M -100s & some F&M-250 series, 2Wd, from 61 thru 79, for all intents & purposes, either are 57-64 style with 4 leaf springs & single I beam front axle. Or else 65-79 style with twin I beams, 2 front coil springs, & 2 rear leaf springs. Notice I said STYLE.
I do not want to imply 65 thru 79 Chassis's are all the same as they are not, altho they do interchange relatively easily due to their many similarities, IMHO. But that's a different topic for another post, altogether.
FBp
sherlock375
Jan 21, 2011 04:25 AM
Cbattinjr
New Member Introductions
Jan 21, 2010 11:55 AM
jfarcas
Jan 15, 2008 06:05 AM
numbersix
Nov 23, 2006 04:49 PM
mirabida
Aug 17, 2003 08:16 PM
