hesitation
Old May 28, 2002 | 06:00 PM
lucky3380's Avatar
lucky3380
hesitation
over the weekend I was at my parents house and had the chance to do some fishing....was having fun untill my fathers 93 f-150 started to have some problems. When you start to accelerate the truck will start to studder, then you can let off and push lightly and it will be better. any time the engine is under a load ( ie...acceleration and stomping it) the truck will cut out. It even died trying to cross the intersection. I checked the exhaust...its fine...the only thing I can think of is something with the fuel. When you run on the back tank it only hesitates a little then you can switch to the front tank but if you start on the front tank it will most likely die a couple times first before you can go anywhere. My guess was to bypass the fuel selector valve and see how it runs but if someone know's the answer I would love to hear it. I am getting sick and tired of hearing my dad say he should have kept his old chevy. Thank you for your time.
Old May 28, 2002 | 06:03 PM
lucky3380's Avatar
lucky3380
hesitation
sorry...I forgot to include that it is a 4.9 and also when it starts acting up the overdrive light starts flashing on and off.
Old May 28, 2002 | 07:08 PM
Pensive's Avatar
Pensive
hesitation
I have a '93 with the same prob. Most posts I see about hesitation are coming off of idle. Mine (I think, ours) is a problem with load. I do a lot of highway driving. Once I have to reaplly speed, she starts stumbling pretty bad. It's gets up there, but it's not pretty.
Help!
james
Old May 28, 2002 | 09:23 PM
lucky3380's Avatar
lucky3380
hesitation
well...it looks like we are in this together...lets find a solution huh?
Old May 28, 2002 | 09:59 PM
Vampiro's Avatar
Vampiro
hesitation
fuel filters, clogged injectors, something in the lines? i don't know too much about the newer trucks, but im just throughing out ideas
Old May 29, 2002 | 07:47 AM
GammaDriver's Avatar
GammaDriver
hesitation
Sounds like plenty of reason to start using the SEARCH function of this site for "EGR" and "Restrictor (plate)". It sounds like the classic EFI 4.9 symptom in need of the 'fix'.
Old May 30, 2002 | 05:27 PM
gpachner's Avatar
gpachner
hesitation
I had a similar problem with my 90. It turned out to be the MAP sensor.
KWIKI
92 F150 4X4
4.9,5 SPEED
Old May 30, 2002 | 06:41 PM
brown 4x4's Avatar
brown 4x4
hesitation
JohnnyMantic
Dec 18, 2013 06:27 PM
SurfsUp
Mar 6, 2013 11:00 PM
rmdohen
Oct 4, 2010 08:00 PM
2000ExpXLT
Dec 8, 2005 10:16 AM
eric in tn
Sep 25, 2003 12:08 PM
