Tools for frt wheel bearing change 99 f150
I am going to change both of the hub assemblies on my 99 f150 4x4 (12mm studs) because an idiot at a tire place tightened the wheels so tight he warped the hubs and I can't keep the rotors from warping. the hubs alone have .014 of runout. I am familiar with the procedure for removing and replacing them, what I need to know is what size socket I need to take off the axle nut and size socket for the hub bolts?? Torque for axle nut?
Thanks!
Thanks!
i also think th eaxle was 32mm for the F150... the hub bolts are 15mm heads. dont buy a wrench at Wal Mart. Get a 6 point wrench like craftsman that you can smack with a 5 pound hammer or those three bolts wont budge. they may have loctite on them , some say heat will help, i only use the BFH. take the axle nut off and push the axle in an inch , that gives more clearance on the bck for the 15mm wrench.
Macs1964F100
07-15-2014 07:32 AM
RA81222
03-20-2006 02:26 AM
