Question about the CCV Mod
Old Nov 13, 2007 | 12:26 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
I was wounder if you can just run a hose all the way to the back of the truck and let it vent out there insteasd of making a cup to hold it. What sise hose do I need and what kind of right angle piece do I need. Where can I get all of this suff to do this. Also what are the risk of doing this mod. I dont want to blow seals.
Thanks,
Nick
Old Nov 13, 2007 | 12:54 AM
kbeefy's Avatar
kbeefy
I think that was the early CCV mod. Seem to recall something about smell and driping leading to the catch-can.
Old Nov 13, 2007 | 01:11 AM
Izzy351's Avatar
Izzy351
Most of us just do just that. I have mine crossing over at the rear axle so it vents near the exhaust after going up over the brake master cylender. Not that big of deal. Never any drips and not that much of a smell unless you stick your nose in the passenger side rear wheel well. I used 5/8s or 3/4 heater hose (can't remember exactly now), but if I were to do it again, I'd get some of that clear stuff from Home Depot or Lowes so I could see if there was any pooling in low spots. There are many ways to skin this cat, so do what you think will work best for you, don't have any kinks, and make sure it's always sloping away from the engine.
Old Nov 13, 2007 | 01:16 AM
ernesteugene's Avatar
ernesteugene
Thanks,
Nick
Here are several recent links to read, then if you've still got more questions just ask here.
Oil Leak after CCV-Delete
https://www.ford-trucks.com/forums/669993-oil-leak-after-ccv-delete.html#post5311716
CCV smokin'
https://www.ford-trucks.com/forums/669729-ccv-smokin.html
CCV question...
https://www.ford-trucks.com/forums/671529-ccv-question.html
Old Nov 13, 2007 | 10:33 AM
weekendwarriorfsw32
Master of Strokes
So from what I hear 1 inch hose is the best and you want clear hose to see if there are any thing stoping the flow in the pipe. Can I get all this stuff at the Home Depot or a hard ware store,
Thanks,
Nick
Old Nov 13, 2007 | 11:07 AM
F250_'s Avatar
F250_
Ultimately, the clear hose may end up cracking, because it is only vinyl. That said, it is what I used so I could see how things are going. Once I read about folks experiencing frozen up CCV hoses and not being able to know where it was frozen, I decided to go the clear vinyl route and perhaps change it out every 2-4 years. It is readily available at either Home Depot, Lowes, or other hardware store.
Old Nov 13, 2007 | 02:04 PM
ernesteugene
Thanks,
Nick
See post #12 of this thread for a link to the hose that I recommend. It will not kink or degrade. I've had one laying out in the sun for 9 years with the waste from my black and gray holding tanks flowing through it, and it's still as good as new!
Recent mods, CC pressure gauge, CCV, and DP Tuner!
https://www.ford-trucks.com/forums/607571-recent-mods-cc-pressure-gauge-ccv-and-dp-tuner.html
Old Nov 13, 2007 | 03:13 PM
weekendwarriorfsw32
Master of Strokes
So I should be able to go to my home depot and get a hose.
The other hose is expensive that from caming world. Last question how big is the outlet comming out of the dog house.
Thanks
Nick
Old Nov 13, 2007 | 03:40 PM
F250_'s Avatar
F250_
If you keep the existing rubber elbow that comes out of the doghouse, a 3/4" pvc hose nipple and a 3/4" vinyl hose will work. They are both available from home depot.
Old Nov 21, 2007 | 12:41 PM
weekendwarriorfsw32
Master of Strokes
Well I just did this last night. It took me 1 1/2 hours. I have pics to post later but I have a question when I start up the truck a white ish smoke comes out of the pipe is this ok
Thanks
Nick
Old Nov 21, 2007 | 12:56 PM
ron's power stroke's Avatar
ron's power stroke
Thanks
Nick
that is normal..if you dont see smoke..you have a pluged hose..
Old Nov 21, 2007 | 03:13 PM
F250_'s Avatar
F250_
Depending on which oil you're running, you'll get different amounts of smoke and different odors from the CCV.
Old Nov 21, 2007 | 03:26 PM
guitarpicr's Avatar
guitarpicr
Nick - Like Pete said the smoke is nothing to worry about . I think just about everybody whos done this has a little smoke .Kinda fun at the drive thru window when people ask if your truck is on fire. LOL
Old Nov 21, 2007 | 04:29 PM
weekendwarriorfsw32
Master of Strokes
Thanks guys that what I wanted to hear,
Nick
