Boost PSI
Old Nov 13, 2007 | 04:23 PM
powerstroked162's Avatar
powerstroked162
supposedly a certain computer code, i think its ADO1 or something like that, defuels after 22psi. So if you get a regulator Neal, set it at 20lbs-ish and you should be good to go.
Cowboy Steve
Old Nov 13, 2007 | 05:09 PM
tjbeggs's Avatar
tjbeggs
I have it set around 22-24 psi. its a regulator. You can use a relief valve but I don't like to create boost leaks so I like the regulator
Old Nov 13, 2007 | 05:17 PM
powerstroked162
There's alot who dispute the OBS 7.3's defueling but alot have had it happen to them. The idea about it is that there are certain PCM codes that do it so not all may be affected by this plaque but the regulator is the best way to find out. Im gonna do it this weekend and see if it does anything for me.
Cowboy Steve
Old Nov 13, 2007 | 05:21 PM
tjbeggs's Avatar
tjbeggs
The defuel in the OBS have isn't like the Superduty defuel. On my truck it felt more like the rev limiter on a gasser hitting. But it wasn't near redline but boost was 30-33psi. Put in the regulator and it went away. Superduties will set a CEL most of the time and loose power until you turn off the engine and start it back up atleast I think that is the way it works on the SD.
Old Nov 13, 2007 | 05:23 PM
powerstroked162
I read on over on thedieselslop.com that our exhaust backpressure sensor can also trip a defuel pattern. So they do something called the doogle mod. Have you heard anything about it before?
Cowboy Steve
Old Nov 13, 2007 | 07:17 PM
jboard's Avatar
jboard
I can usually hit 22-23 WOT no defuel problems.
--------------Jeremy
Old Nov 14, 2007 | 11:03 AM
Neal 97 250's Avatar
Neal 97 250
I can still hit 25 with uppipe leaks.
Old Nov 14, 2007 | 11:53 PM
powerstroked162
The de-fuel dosn't occur in certain trucks with certain computer codes. The trail of computer codes affected by de-fuel is starting to form so shortly we should know what trucks have the plaque and which ones dont. Remember that a de-fuel wont stop the turbo from building boost past 22lbs(the point of de-fuel) as its not a wastegate or blow-off valve. I think my truck de-fuels as it feels weak when it starts seein boost numbers over 24lbs. So Im gonna do the regulator mod and see what happens. Tim, what regulator di you buy, where, how much, got a write-up on install and regulator tuning?
Cowboy Steve
Old Nov 15, 2007 | 04:20 AM
tjbeggs's Avatar
tjbeggs
here you go Steve. the first two pics have my write up about what its is
http://good-times.webshots.com/album/558926270AQyXsy
Old Nov 15, 2007 | 10:14 AM
powerstroked162
Thanks Tim
Cowboy Steve
Old Nov 15, 2007 | 10:35 AM
FARM69's Avatar
FARM69
Looks like you can get these regulators pretty much anywhere(Menards, Lowes, Home Depot, etc). Good work TJ.
Old Nov 15, 2007 | 02:01 PM
tjbeggs's Avatar
tjbeggs
Thanks but its not my orginal idea. Got it from a few others and the Superduty guys.
dclack
Dec 31, 2011 10:24 PM
shark1979
Jan 23, 2010 10:17 PM
az400w
Jul 14, 2009 08:14 PM
cdiddy
Jan 4, 2008 11:38 PM
mjlewis
Oct 17, 2006 03:09 PM
