72 F100 Engine Mounts
Old Nov 12, 2007 | 06:31 PM
RangerJamesW's Avatar
RangerJamesW
When swapping a 360 over to a 302, I know I need different motor mounts that bolt to the block. Do I also need new frame stands that bolt between the frame and the mounts?
Old Nov 12, 2007 | 07:22 PM
Dave Severson's Avatar
Dave Severson
I put a 351W in my '71 where a 360 had been, everything worked fine....
Old Nov 13, 2007 | 02:22 PM
dhglaser's Avatar
dhglaser
David,
So you were able to use the same perches?
-David Glaser
Old Nov 13, 2007 | 07:15 PM
Dave Severson
Yup, didn't change a thing....Now if I could remember which motor mounts I used..... Sorrry, CRS is kicking in again!!!!! There are some pics of the installed engine in my gallery if that will help you any.....
Old Nov 13, 2007 | 07:20 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Dave, GOT SNOW!
56*F nights and 68*F days my area.
Old Nov 13, 2007 | 07:55 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The 302 engine was first offered in 1969 F100's.
Old Nov 13, 2007 | 08:48 PM
convincor's Avatar
convincor
FE perch's are actually 1" taller than the 302 perch's.
They'll work, but can cause driveshaft alignment issues.
Pic show's the difference.
lowtrkn2k
Sep 7, 2012 02:17 PM
cujo8
Sep 24, 2011 12:28 AM
garbz2
Feb 17, 2011 11:09 PM
towmaster
Sep 19, 2007 06:45 PM
