97 bad start, wont turn many r's
hey i looked at a 97 CC LWB 5 sp this last week. it started after about actual minute of cranking, petal on floor. then it started blew white and blue smoke till i shut er down, 10 min later, and for a bout 5 min, even if floored it only turned like 1000-1200 rpm's
Corect me if im wrong, but im almost sure it does no good to push the pedal to the floor when starting a electronically controlled engine like our powerstrokes. I always wondered that actually. the old mechanical ones you could do that too cause you foot was directly connected to the pump.
------------Jeremy
------------Jeremy
------------Jeremy
------------Jeremy
I don't know if the PCM looks at TPS before the injectors fire.....
i had the same prob i found that 6 out of 8 glow plugs were bad two injector harnesses were bad and i replaced my fuel pump. and my truck wouldnt even start if i didnt have it on the floor. i also replaced my fuel filter before i replaced all of those parts. after i spent all that money it still didnt fix it. i took a look inside the fuel filter canister and noticed a bunch of things floating and noticed my filter was a diffrent color. I drianed all of the fuel out with that fancy yellow lever and filled it up a couple of times and repated this process until there was nothing in there. then let the truck run for a while. if you find that one of the harneses are bad i have an extra on and also know where you can buy them for 29.99 brand new or 20 used
powerstroke97hd
01-17-2011 08:33 PM
Dozer99
47
12-11-2010 07:05 AM
