Sponsored by: Auxito
Clicking after start up:
Old Nov 11, 2007 | 08:12 PM
Residence's Avatar
Residence
Question Clicking after start up:
00' F-150 XLT S/C 5.4
I start up my truck it's perfect. I back up out of my drive way; put it in drive and step on the gas. (click,click, click, click, click)
It's more than 5 clicks, and it stops after about 10 seconds.
I wait for the engine to warm up most times. It's hit or miss at times.
Some people say it sounds like a lifter tapping, and my neighbor said a "tap-it?
I have to say. It doesn't sound like it's internal, and only happends for a few seconds. Only when I step on the gas when first going somewhere.
Anybody have an idea what this could be?
Thanks,
Rez
Old Nov 12, 2007 | 12:33 AM
RedDragon777's Avatar
RedDragon777
is it a 4x4, cause when you switch between 2hi and 4hi it makes a clicking noise and it clicks a couple of times then it goes away to show the t-case is engaged or disengageing
Old Nov 12, 2007 | 10:20 AM
StephenH's Avatar
StephenH
Rock stuck in your tire?
I would check for something loose.
Do modulars even have lifters?
Old Nov 12, 2007 | 07:02 PM
mudvayne0882's Avatar
mudvayne0882
Same Problem
I have the exact same problem with my 00 F150 4X4 5.4 liter. It makes the tapping noise for about 10 seconds, and then goes away. only makes the noise when stepping on the gas. It is not the 4 wheel drive, and it is not a rock in the tire. It has to do with something under the hood, as it sounds like it comes from the passenger side under the hood. It stops making the noise after about 10 seconds. Any information would be helpful, as I am lost.
Old Nov 13, 2007 | 09:07 AM
KingRanchMan02's Avatar
KingRanchMan02
Broken exhaust manifold studs anyone? Good luck!
Old Nov 13, 2007 | 09:15 AM
fordboy_52's Avatar
fordboy_52
i vote broken studs. my dads is doing the same thing
Matt
Old Nov 13, 2007 | 08:06 PM
02crew's Avatar
02crew
i think i have the stud issue also. going to check this weekend if its not too cold. how do you replace the studs that are broken?
Old Nov 14, 2007 | 10:48 AM
KingRanchMan02
Take a look at the exhaust manifolds on your truck, in particular at the fasteners that hold them in place. The problem is that the OE studs rust away and break off resulting in the ticking noise.
The solution to the problem is to replace ALL of the studs and nuts with the stainless steel parts available from the Ford dealer parts department. Replace the exhaust manifold gaskets too. It helps to remove the inner fender liners to gain access to the studs and nuts. Good luck!
Old Nov 14, 2007 | 08:21 PM
RedDragon777
if you do not want to get them from a ford dealer the next best thing is finding a store that sells ARP studs, alot of drag racers with high HP and TQ only use ARP studs
Old Nov 14, 2007 | 08:59 PM
02crew's Avatar
02crew
i cant imagine that those are fun to take off, the studs? any tricks?
erik_bishop
Apr 4, 2024 11:51 AM
fifty-two_f1
33
Dec 1, 2019 08:20 PM
stevenailor
Sep 24, 2015 07:44 PM
jeepfix
Aug 22, 2015 09:18 AM
gene jr
Jun 9, 2015 11:45 PM
