How's about a 429?
50HP moves 125lbs very easily.
My 393 had to come out because it wasn't running right and I couldn't get the bugs out of it. I didn't want to ruin it and I pulled it to put a good stock 351 in its place. I have a couple of modifications on it but it's still basically stock. I still have problems with the way this engine runs but it's getting better.
What system did you use?
"Went to my local engine builders today..." or something like that.
You might post a link for the further edification of the masses. I read darn near the whole thing when I first came here. It was good pretty & interesting.
If you do a search for my user name in the 302/351 engine forum you should find that thread.
I'm still not exactly sure but I know detonation was a problem. It ran for about 5000mi.
STFT's and LTFT's monitoring vs. %engine load would identify blatant issues. Injector width, MAF frequency issues, Short-Term Fuel trim can all make or break a well built motor. A data logger in your service port could monitor your sensors and help identify induction issues.
A wideband with gauge in your cluster to monitor A:F full time might prevent this in the future. No need to tater the next lower end you throw in that motor.
Take a look at the sct pro racer package if you are serious about that stroker. I think you'll find the tuning a lot less daunting than you previously thought (or at least I thought!). The support for the product both OEM and forums is incredible. Not to mention... a couple of tunes and some dyno time and the setup pays for itself.
You will also watch your rig a lot closer, monitor values more diligently than your average tuning shop. Not to mention... dial your rig for your style of driving... everyday street manners...not just WOT performance.
Just a thought... from someone who appears to be another DIY'er kind of guy.
Blurry94 is a member that is well versed in this field and helped me get started on my DIY tuning quest. Pick his brain if you have any in-depth questions. I bet he'd lean towards tuning/EFI issues for your previous detonation problem.
Good Luck,
Mike
But I know that detonation wasn't part of a tuning issue regarding the EFI. It was the way it was built. I was being vague because I didn't want to really dive into it because it's a long story but it goes like this...
When I did it about 3 years ago I didn't know very much about it. I had a company build my shortblock and I wanted mild compression. He told me to use a thicker head gasket and I've learned you can't do that because the quench height is sacrificed. I had way too much of a quench height and it causes detonation. I had good A/F ratios, mild timing, and aluminum heads with only 9.5:1 compression and it still detonated unless I backed the timing off even more and had 93 in it. You could also hear how it wasn't burning the fuel correctly.
Thats why I pulled it out after only 5000k mi. I couldn't get it to run right w/o switch head gaskets and tweaking some other things that cost $$ and time I didn't have so I put a slightly modified 351 in it's place.
In the last 3 years I've really studied the process and learned quite a bit so I'm comfortable building them myself now...just don't have the money to build one.
The motor in my truck has about 200,000 miles on it. It still runs good but it leaks and I'm looking at picking up a better 351 and putting some of my performance parts on it. Won't cost much for over 300hp and very little vehicle downtime.
