Drivers side armrest......
Old Jul 28, 2009 | 07:09 AM
seanreit's Avatar
seanreit
Originally Posted by jayyslow
if you are talking about the inner armrests, all you have to do is remove the cover off of the foam pad by starting where it hinges, there is an elastic band and all you have to do is pry over foam and slide off, then put your driver side cover onto your passenger and passenger onto drivers. basically all it does is flip the leather so the bottom side is up and hide the cracked portion on the bottom. very easy to do.
I did this, took 10 minutes. I'll buy new ones when the switch a roo wears out too
Old Jul 28, 2009 | 04:18 PM
Elmo154's Avatar
Elmo154
Try The Seat Shop!
Try The Seat Shop... save yourself some money. It will cost nearly twice as much from Ford.
The armrest covers are not reversible. You cannot switch them from left side to right side either.
Good Luck!
Old Aug 27, 2010 | 11:00 PM
snavemit's Avatar
snavemit
Works great!
Thanks for this post. I pulled the two arm covers off the front seats and switched them and it is like I have new arm rests. The drives side was so bad as the previous owner had sewn it back together on the seam I was getting an abrasion from it rubbing my arm. Took about 5 minutes.
Old Aug 29, 2010 | 02:12 PM
seanreit's Avatar
seanreit
Ya, unfortunately, Elmo154 is just wrong. You can switch the armrest covers no problem. A year later and mine are holding up just wonderfully.
Old Aug 30, 2010 | 05:28 AM
locknload223's Avatar
locknload223
I did mine the other night, less than 5 minutes. I pulled them off from the driver's seat then hopped in the center back seat for more leverage to pull them back on. Great mod!!
Old Aug 30, 2010 | 09:35 AM
Pickupmanx2's Avatar
Pickupmanx2
Yup, did mine earlier this year,,,, so glad
Old Aug 30, 2010 | 12:30 PM
slenser's Avatar
slenser
I did the the produce baggie trick as mentioned on the seat shop's how-to...slick as <censored>! I got the baggies before trying it and decided, just for kicks, to put one on without a baggie and it was pretty hard. I decided not to finish and give the baggie trick a try and it slid on VERY easy! I'm know I could have put the armrest on without the baggie, but why? I'm loving the nice smooth armrest I have. Thanks guys!
I was wanting to buy a new seat cover for the driver's side, but at $300 from the seat shop for just the seat bottom I can wait a little longer. There are more urgent needs for this thing.
slenser's Avatar
slenser
Not sure how the double-post happened...oops
Old Sep 1, 2010 | 05:36 PM
Marlinda's Avatar
Marlinda
I did this and thanks to you it worked out great!!!!!
Old Oct 20, 2015 | 03:04 PM
Half Breed's Avatar
Half Breed
Wish I could find one for my drivers side seat, which has the one on the in side next to the console. Doesn't matter the cover I have a cover HELP!!!!!!!!!!!!!!!!!!!!!
Half Breed
Old Oct 20, 2015 | 08:48 PM
Apocalypse's Avatar
Apocalypse
Half Breed
Wait, what?!?!?!?!!!
Old Oct 21, 2015 | 06:49 AM
Half Breed's Avatar
Half Breed
I'm looking for a fold down armrest for my drivers seat in my 97, F-150
Old Oct 21, 2015 | 06:54 AM
  #28
WE3ZS's Avatar
WE3ZS
You might have better luck in that truck's section of the forums.
BigGreenEx
Jun 27, 2022 04:27 PM
vacuumbed
Jun 13, 2017 03:06 AM
Ronnief150man
Apr 18, 2016 02:45 AM
1965F100
Apr 15, 2016 11:31 AM
DattMavis
WTB - Parts & other
Jan 19, 2016 03:41 PM
