Ignition Switch Lock Cylinder
Old Jul 24, 2015 | 06:04 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Excursion broke down on the wife yesterday. She turned the corner on a (fortunately residential) street, and the truck died. Lost all power, steering and brakes. NOT A GOOD SCENARIO FOR ANYONE. She tries to restart, and the key just spins in the ignition without any resistance.
I figured it out and got it all fixed. Cost me $166 for parts and labor. This is a very uncommon problem. Is anyone interested in knowing the in's and out's of this failure and fix? I always put up lots of photos It will take me considerable time to put it all together in pics and such, so I want to gauge interest before I go to the trouble.
Old Jul 24, 2015 | 06:14 PM
psycoreefer's Avatar
psycoreefer
I'm interested, our key sometimes gets stuck, such that you can't turn it to start the truck. I've had this happen on other vehicles when the steering wheel is turned to full lock, but this isn't the case on the ex - it can get stuck even when parked on level ground with the wheel straight ahead.
I suspect the problem might be the same parts you had to replace....
Old Jul 24, 2015 | 11:25 PM
Stewart_H's Avatar
Stewart_H
Are hot chicks doing cosplay now driving all the virgin nerds crazy?
Anything that adds to the knowledge base in the tech folder is a very good thing!
Please do the write-up!
Stewart
Old Jul 26, 2015 | 06:50 AM
harley4jcs's Avatar
harley4jcs
X3 I'm sure it will happen to all of us at some point.
Old Jul 26, 2015 | 06:55 AM
wpnaes's Avatar
wpnaes
X4 Mike, plus you'll be famous on FTE!
Old Jul 26, 2015 | 11:32 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Working on this write-up this week.
Old Oct 5, 2015 | 09:07 AM
Hitagain's Avatar
Hitagain
I want to post a something to try if you have the ignition switch lock up on your truck. My excursion key wouldn't turn so i called a locksmith to come out and fix it. He told me to jack up the front end and see if i could turn the key and it worked. He told me that 90% of the calls he get for this issue tells the owners to jack the front end up to get the pressure off the front wheels and you can then turn the key.
Old Oct 5, 2015 | 05:37 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Yeah, mine is fixed. The cylinder snapped in half inside the chamber it plugs into (manufacturing defect in the aluminum casting). I have all the pics for the write-up, but the tranny went out 2 weeks ago and I have been a bit pre-occupied with that.
Old Oct 5, 2015 | 06:13 PM
Stewart_H's Avatar
Stewart_H
No need to jack up the front end, this is a common occurrence that frequently happens when people have their wheels turned and they turn the key off prior to, or at the same time they release the steering wheel.
When that happens, the steering wheel lock kicks in, keeping the wheel from turning back, putting pressure on the steering wheel lock.
All that needs to be done is to grab the steering wheel and turn/pull the wheel back into the turn (the same way the wheels are turned) and that will take the pressure of the lock, allowing a person to turn the key.
Ref thread: https://www.ford-trucks.com/forums/1...l#post13562284
Stewart
Old Oct 5, 2015 | 06:33 PM
Hitagain's Avatar
Hitagain
Could not turn the wheel to unlock it no matter how hard you pulled. There was 2 of us pulling on the wheel and it wouldn't unlock. Jacked the front end up and the key turned like the steering wasn't even locked.
Old Oct 5, 2015 | 07:02 PM
Stewart_H's Avatar
Stewart_H
J/K of course.
If there were two of you guys yankin' on the wheel, then I guess you had to use a jack!
Stewart
Old Oct 5, 2015 | 10:03 PM
Vwags's Avatar
Vwags
And you tried turning it both ways?
Old Oct 21, 2015 | 07:31 AM
harley4jcs's Avatar
harley4jcs
SURE, One guy was pulling left while the other was pulling right. Could not get that sucker to move for s***.
TexasGuy001
25
Jun 10, 2019 05:42 PM
akornzombie
May 27, 2007 12:52 AM
yorxs
1983 - 2012 Ranger & B-Series
Jan 11, 2006 08:22 PM
scout7
Sep 25, 2003 08:07 AM
bretanamc
Aug 15, 2002 11:33 AM
