Engine quit, no start
Old Nov 11, 2007 | 12:13 PM
jkopec's Avatar
jkopec
Hello all. I have been using your site for years, a tremendous wealth of great info, but this is my first time posting. I have a 96 F350 PSD, 160K all stock. Truck has been running great, the only problem has been the alternator is starting to go, the battery light comes on intermittently, but I was going to replace that next week. I was driving the truck today, and it just shut off. Now I have no Wait to Start lights, no smoke out the tail pipe, and no RPM when cranking. Engine cranks well, batteries are good, and fuses all appear good. Any thoughts? Thanks!
Old Nov 11, 2007 | 12:19 PM
Action4478's Avatar
Action4478
First thing to check would be fuse # 22 in the distribution box under the hood,,,If it is blown, unplug the fuel heater & replace the fuse....
Old Nov 11, 2007 | 12:21 PM
Action4478's Avatar
Action4478
Heater location....Here....
BTW , pardon my manners...
Welcome to FTE.....
Old Nov 11, 2007 | 12:47 PM
tjbeggs's Avatar
tjbeggs
Welcome to FTE!! And Rick has you going in the right direction! let us know what you find.
Old Nov 11, 2007 | 01:02 PM
jkopec's Avatar
jkopec
Rick,
When I checked the fuses this morning, I forgot to check in the distribution box. Sure enough, #22 was blown. What do you mean my unplug the fuel heater? I can't see any bad wires in there, what are the chances that the fuse just went bad because because of age? I have a long drive home tonight and don't like the thought of getting stranded.
Old Nov 11, 2007 | 01:08 PM
MagKarl's Avatar
MagKarl
The heater element is in the bottom of the fuel filter canister, they deteriorate over time and short out. Removing or unplugging it should prevent you from getting stranded again. If you're in a hurry, just unplug it, if you have the time, pull the fuel filter and investigate further.
Old Nov 11, 2007 | 01:10 PM
Neal 97 250's Avatar
Neal 97 250
Keep some extra fuses in case. The fuel heater can be unplugged from the side of the Fuel filter housing. Sorry no pics I will try to find some...
Old Nov 11, 2007 | 01:35 PM
MADVAN's Avatar
MADVAN
Where are you Rick!
He has links and photo's a click away!
I have none.
Bill
Old Nov 11, 2007 | 01:46 PM
Neal 97 250
I have seen the pics but can't find them right now.
Old Nov 11, 2007 | 03:08 PM
1997F-350's Avatar
1997F-350
on the side of the bowl is 2 red wires. unplug the top red one. install new 30 amp maxi fuse. drive truck tonight. replace heater later if you want to.
Old Nov 11, 2007 | 05:55 PM
jkopec's Avatar
jkopec
Thanks for the pic Rick, and thanks to everyone for all the great info. I have disconnected the heater, replaced the fuse and the truck fired right up. It will at least get me home now, and I will replace the heater this week. Thanks for all the fast responses, you all really helped me out of a jam! Can't thank you enough!
John
Old Nov 11, 2007 | 08:16 PM
tjbeggs's Avatar
tjbeggs
I wouldn't bother replacing the heater depending on where you live. What is the lower average temps is winter you see?
Old Nov 27, 2007 | 11:42 AM
jkopec's Avatar
jkopec
Thanks again for all the posts everyone. I just installed a new fuel heater. I live in Connecticut, and we do get several nights a year well below 0, I figured for the $50, it was worth it, and if it goes bad again, I have spare fuses with me. Saw on another thread that the nut that holds the fuel heater in place is a LEFT HANDED THREAD! Glad I stopped what I was doing to check with the experts before I ruined it, since I couldn't get it out the usual way. BTW, a basin wrench for a sink works perfectly for getting at the nut. Thanks again everyone!
Old Nov 27, 2007 | 01:15 PM
Neal 97 250
Congrats on the fix. Thanx for the tip on the basin wrench.
jmaskew
Nov 10, 2015 03:56 AM
airports1
May 28, 2015 03:43 PM
bbacon
Jul 2, 2014 11:28 PM
lifted77f250
Mar 26, 2011 04:58 PM
andym
Feb 1, 2010 07:42 PM
