t/c ?
Old Nov 27, 2007 | 12:55 PM
bobpat204's Avatar
bobpat204
t/c ?
my troque converter is kicking in i out i think, the truck kicks up and down 200-300 rpm with the o/d off on at any speed. the cruise control if it is on does not kick off,i looked at the brake lights the brake switch my question is will the brake system cause the t/q to lock/unlock without kicking the cruise off?
Old Nov 27, 2007 | 02:16 PM
gt8684's Avatar
gt8684
have you checked your fluid level? does it look/smell burnt? my buddy has a chevy truck that did that, he was short a quart... does your truck take a longer time than normal to take gears, like when you move from park to drive or reverse?
Old Nov 27, 2007 | 02:18 PM
Cuda_jim's Avatar
Cuda_jim
Yes, the brake switch under the dash (BOO) will kick the TC off. The switch on the master cylinder (BPA) turns the CC off.
