Ignition switch replacement on 96 Explorer
Old Nov 11, 2007 | 06:17 AM
dcara's Avatar
dcara
By removing fuse#1 I have determind that what keeps causing my battery to go dead is a current drain through the ignition switch. The ignition switch has deteriorated to the point that even without a key in it, it just rotates this way and that. Due to this I suspect it is keeping the PCM power relay, and ICM module energizied all of the time thus draining my battery after sitting for about a week. Although I still have to use the key to start it. Anyway it seems it is time for a new ignition switch. How diffacult is it to replace the ignition switch and how does one go about doing it?
Old Nov 11, 2007 | 01:47 PM
Franklin2's Avatar
Franklin2
Here's a picture of it.
http://www.autozone.com/images/cds/g...3d800bca6d.gif
REMOVAL & INSTALLATION
1.
Disconnect the negative battery cable.
2.
Remove the steering wheel.
3.
As necessary, remove all under dash panels in order to gain access to the ignition switch.
4.
As necessary, lower the steering column to gain working clearance.
5.
Disconnect the ignition switch electrical connectors.
6.
Remove the ignition switch retaining screws from the studs. Disengage the ignition switch from switch rod. Remove the switch from the vehicle.
To install:
7.
Position the lock cylinder in the LOCK position.
8.
To set the switch, position a wire in the opening in the outer surface of the switch through its positions until the wire drops down into the slot.
The slot is in the bottom of the switch where the rod must be inserted to allow full movement through the switch positions.
9.
Position the ignition switch on the column studs and over the actuating rod. Torque the retaining nuts to 40-64 inch lbs. (4.5-7.2 Nm).
10.
Remove the wire from the slot in the housing. Continue the installation in the reverse order of the removal procedure.
Old Nov 11, 2007 | 09:14 PM
dcara's Avatar
dcara
Thanks. From the pics and your description it appears that the key cylinder and the actual ignition switch are 2 different parts. If this is true then I wonder if the real problem is that the key cylinder is the actual culprit since it just flops around and possibly engages the ignition switch in error. What do you think?
Old Nov 11, 2007 | 10:45 PM
Franklin2's Avatar
Franklin2
It could be. I haven't worked on Explorers much, but notice the elec switch is still up in the top of the column.
On a pickup, the mechanical part is up in the top like your Explorer, but there is a rod that runs all the way down the column and the ignition switch is actually under the dash on top of the column. They have a pesky little piece made out of potmetal that breaks all the time in those that will let the switch go to run, but will not push it enough to make it go to start and crank the engine over.
rswhitmore
Aug 11, 2016 07:58 PM
Scorcher21
Aug 6, 2016 12:02 PM
stormdraconis
1978 - 1996 Big Bronco
May 17, 2010 11:19 PM
geoaigel
Dec 1, 2009 09:55 PM
jevfro
Electrical Systems/Wiring
Oct 15, 2003 05:53 PM
