Looking for some help about the 4R70W truck transmission. Will a 2002 transmission work in a 1997 truck? Both transmissions are from a 4X4 F-150 with a 4.6 engine and both are the 4R70W trans.
Thanks for any help someone can give me.
Yes, it should work... make sure all the connectors are the same in the trannys...before you install the new one.... i think my speed sensor was a different hookup, so i just swaped it over...
Let me know how it turns out....... I'm thinking about installing a 5.4 in my truck at the same time I do the transmission. The only thing I can't do myself is the computer change.
ranger, if your doing the engine and trans, in a 97... you migh tbe cheaper to sell and switch to a 2002 with the 5.4 already... computer can be a pain.
That's the only reason I haven't done the swap already. I don't know anyone around here were I live who has got the computer part right. I've had the truck for over 10 years.... it's kind of hard to let go.
