Worth a custom exhaust
I don't like flowmasters myself (I hate the resonence).
I'd rather straight pipes.
But for a good muffler on these trucks, the magnaflows sound great.
That price isn't to bad(I guess my area has real cheap prices).
I put a glass pack, y-pipe for the duals look w/ 3.5"x22" chrome tips for $140. Believe me I know the magnaflow would be more expensive, but still a extra $100 would be $240.
Like everyone esle is saying, go for it, but get a magnaflow.
Originally Posted by mred33
Stopped by a local muffler shop and talked w the guy. He said he could run true duals and flowmasters out the back for $300.. Hows this sound, worth getting the true duals??
It did cost an extra $25 for the Magnaflow 3" to 4" stainless tip. There are a number of options available (check out the Magnaflow website). I went with the 15 degree bevel. Really finishes things off nicely and is welded on not clamped. I once priced a Ford clamped on stainless tip and they wanted $172 and I think that the clamp makes them look Mickey Mouse.
I will try to get pictures on later today. I'll take some pics in the dyno room as well. They did the dyno room up according to Mustang Dynamometers recommendations and it is amazing how little space it actually takes and how clean it looks. Performance Plus here in Saskatoon are serious race car builders and a truly classy operation. Their dyno will handle up to 1750 rwhp.
Note: Just took my own advice and spent a few minutes on the Magnaflow website. Very informative and well designed site. Spend some time on there and it will make you confident that some sort of Magnaflow arrangement is the way to go. You'll also be able to ask better questions when you get back to that exhaust shop.
Originally Posted by wreedZ71
Is it 2.5 all the way from the Cat? If not how does putting say a 3" magnaflow improve anything?
most catbacks ditch the 2.5" neckdowna and continue with 3" piping out the rear if it's a single in, single out
the single in dual out doesn't need the 3" piping for noise...2 pipes are better then one IMO
Went in to book my dyno time yesterday and found out that they changed their minds and are not going to use it again until spring. By then I will be gone to China to teach so I guess I will never get the data.
At any rate it sure seems to me that the exhaust change got rid of that last bit of hesitation that the tuner still hadn't quite taken care of.
I am coming to the conclusion that you cannot make any generalizations about the exhaust that you will find on an F150. My red 04 had a total of 4 cats, but my 04HD only has the two cats in the same arrangement as my 06.
When you follow the posts about exhaust here it often seems that people are disagreeing when it is simply because, for whatever reasons, their trucks have differently configured stock exhaust components. Should be able to ask Ford about this, but I'm guessing that they would be of no help.
how many cats are there? 2?
It's pretty clear to me that you cannot tell how many cats there will be on any given F150 unless you actually have the vehicle right there to check it.
Very clearly some of them have a four cat system and some of them have a two cat system, and why that is I have no idea.
Originally Posted by bigdavewilson
I am hoping to get my truck on the dyno some time this week. I have the numbers (228 hp and 292 ft/lb torque) from before the Magnaflow (generic muffler with 3 inch pipe from just behind the y-pipe) and I want to see what difference the exhaust made. Unfortunately, it is not the same dyno I had for the last runs so I'm not sure how comparable the results will be. Very lucky though to have a Mustang M1100 about 5 minutes from where I live and for $100 CAD an hour (that's about $105 USD these days)
I will post the results once I have them.
