Sponsored by: Auxito
need advice!!!
Old Nov 7, 2007 | 03:00 PM
Fordtrucksrule!'s Avatar
Fordtrucksrule!
need advice!!!
I own a 2002 F-150 4x4 Lariat with the 5.4L. The truck started surging and farting around recently and the cel came on. I had the truck hooked up to my buddies code reader and I got back the following codes;1151,0401,and 1132. What should I check/replace??? Help!!!
Old Nov 7, 2007 | 03:16 PM
Big Bad's Avatar
Big Bad
P1151 - Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Lean - Bank No. 2
P1132 - Lack of Upstream Heated Oxygen Sensor Switch - Sensor Indicates Rich - Bank No. 1
P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient Detected
Old Nov 7, 2007 | 06:04 PM
chrisf250-460's Avatar
chrisf250-460
Check Behind Your Intake For A 90 Elbow Vacuum Line ,you Cant See It Without Climbing Over The Motor.my 1998 5.4 Had A Similar Problem-the 90 Had Ruptered In The Miiddle.
Old Nov 7, 2007 | 07:16 PM
superdutymj's Avatar
superdutymj
Had the same thing happen on my 99 V10, same elbow to blame. The lean/rich codes are from the computer trying to compensate for the vacuum leak. 10-1 this is your problem. Good luck!
Old Nov 8, 2007 | 01:54 PM
Fordtrucksrule!
thanks for the responces!! If it does turn out to be theis 90 degree elbow you are speaking of, where can I get a replacement? A Ford dealership? Thanks again!!!
Old Nov 8, 2007 | 06:53 PM
chrisf250-460
Yes, they have it. good luck.
Old Dec 17, 2007 | 11:53 AM
Fordtrucksrule!
Does anyone here know what this 90 degree elbow is listed as? What should I ask for a t the Ford dealer? What is it connected to behind the engine? So many questions so little time!
Old Dec 17, 2007 | 12:44 PM
LastSplash's Avatar
LastSplash
If the dealer cannot find it on thier parts diagram have them look on the diagram for the V-6 it has the same hose with the same part number. I cant remember if it was on this site or a different one but someone posted about it.
I believe the hose goes from the valve cover to the back of the throttle body, its the only 1" hose back there.
BigHazard
Apr 15, 2010 06:09 PM
4x4fordtrkn
Aug 26, 2004 01:48 PM
Txbullfrog
May 22, 2004 08:46 AM
frey69
Mar 10, 2004 09:55 PM
