Error Code 33
Old Mar 10, 2004 | 01:39 PM
frey69's Avatar
frey69
Error Code 33
My truck was getting a error code 33 (EGR Valve not opening) Changed the EGR Valve and sensor.I erased the codes . The truck is still hesitating when it gets warmed up at around 35 MPH. Ipulled the codes again and am still getting a code 33. Any Ideas?
1988 F-150 351W 4*4 EFI
Old Mar 10, 2004 | 02:31 PM
tulsaokjoel's Avatar
tulsaokjoel
It could be the vacuum line going to the egr valve, or it could be the evr valve. The evr is the valve that allows vacuum to go to the egr valve. (It is on the other end of the green vacuum line that connects to the egr valve.) The Haynes manual has a good procedure for diagnosing this.
Joel
Old Mar 10, 2004 | 03:22 PM
fishmaker's Avatar
fishmaker
Thanks For the reply, I just pulled the codes again now I am getting a error code 32 EVP voltade below closed limit. Any ideas
Old Mar 10, 2004 | 03:34 PM
tulsaokjoel
The EVP is the sensor on top of your EGR valve. You might try putting the old one back on and clearing the codes. Drive it for a while and check the codes again.
Old Mar 10, 2004 | 09:55 PM
christaylor's Avatar
christaylor
Spray throttle body cleaner down the tubes. Had code 33 on my wifes explorer and the same thing happened changed it and the darn code kept coming back. i sprayed the tubes and the light came on once then never again.(sound of knocking on wood)
Chris
Lazarus88
Apr 14, 2016 07:48 AM
canman47
Nov 5, 2015 09:15 AM
Zorfox
Jul 24, 2015 12:30 PM
jgksix
Jul 6, 2015 08:20 PM
mulpha
1978 - 1996 Big Bronco
Nov 10, 2003 07:38 AM
