92 ranger
Old Nov 7, 2007 | 02:28 PM
mmann246's Avatar
mmann246
Question 92 ranger
i have a 92 4.0 ranger and its starts and all but the starter wont disengage it stays on the flywheel ring gear so i dropped the tranny and replaced it because the teeth were worn on it well after doing that i also replaced the battery solinoid and battery cable asembly well after getting all back together i started it and the ground wire that goes from the starter to the soliniod got really hot and melted that plastic casing well now the starter is not disengaging again
Old Nov 7, 2007 | 05:48 PM
87 XLT's Avatar
87 XLT
When you remove the wire with the rubber boot from the starter relay does it stop cranking?
Old Nov 8, 2007 | 02:15 PM
mmann246's Avatar
mmann246
yes it does
Old Nov 8, 2007 | 04:44 PM
87 XLT's Avatar
87 XLT
Ok, looks like the ignition switch is shorted out.
Heres how the start circuit works.
Turn the key to start & the ignition switch connects 12 volts to the starter relay on the "S" terminal. Thats the wire with the rubber boot.
The starter relay closes & connects 12 volts to the starter solenoid on the starter & it cranks.
Try this shift to reverse or drive & reconnect the rubber boot.
If it does'nt crank non stop now, replace the ignition switch.
Old Nov 8, 2007 | 05:26 PM
mmann246's Avatar
mmann246
so the ignition switch just isnt shutting off and thats causing the bendex to stay engaged and not retracting, preety much is what is happening then?? i have a manual would i still put it in reverse then?
Old Nov 8, 2007 | 05:49 PM
87 XLT's Avatar
87 XLT
OOPS, thought you probably had a slugomatic.
DO NOT connect the rubber boot with the truck in gear. Might run yourself over.
Looks like theres a cross in the wiring somewhere between the clutch safety switch & the rubber boot on the starter relay.
Bottom line on a manual is there should only be voltage to the rubber boot when the key is turned to start & the clutch is depressed.
Old Nov 8, 2007 | 05:57 PM
mmann246's Avatar
mmann246
so could that be from hooking something up wrong when i put my tranny bac in or just bad wires?
Old Nov 8, 2007 | 06:44 PM
87 XLT's Avatar
87 XLT
Looks like the red/light blue wire (rubber boot) is crossed with another wire that has voltage on it.
Old Nov 10, 2007 | 07:50 AM
mmann246's Avatar
mmann246
thank you much for your help. i got her goin i had the black wires ****ed up on the soliniod i fell like a retard but yea thatnk you. you told me that so i checked that an now it runs good
Old Nov 10, 2007 | 11:13 AM
87 XLT's Avatar
87 XLT
Thanks for the update, glad to hear you got it figured out.
m.collins
36
Apr 16, 2015 11:42 AM
heavy_d
16
Mar 21, 2014 12:21 AM
fanslowj
1978 - 1996 Big Bronco
Jul 8, 2011 11:50 PM
dgalloway
Apr 29, 2005 08:53 PM
dgalloway
Feb 24, 2005 06:46 PM
