CCV question...
Old Nov 7, 2007 | 06:53 PM
RogueSpear2023's Avatar
RogueSpear2023
Here's some info on how to do it, guzzle also shows how to make an oil trap for his.
http://guzzle.rbmicro.com/ccv1.html
Old Nov 7, 2007 | 07:49 PM
ernesteugene's Avatar
ernesteugene
Originally Posted by HookedOnFuel
Should I vent the CCV to the atomsphere, or route it back into the intake.
The H2E kit has a provision to vent the crankcase back into the intake, I think, anyway. Or is this a provision for a power adder (I did buy this second hand, and don't know what it should look like).
Thanks, Robby
Check post #8 in this thread... https://www.ford-trucks.com/forums/669993-oil-leak-after-ccv-delete.html#post5311716 for what I call the "post CCV mod syndrome" that might result form the higher CC pressure that's caused by any CCV mod. If you have a higher mileage engine your blow by volume might be X4 or more higher than for a lower mileage engine. I recommend a CC pressure gauge so you can continuously monitor for any adverse increases in CC pressure.
Old Nov 7, 2007 | 08:05 PM
SolidGround's Avatar
SolidGround
Personally, not a big fan of the CCV mod. Don't see a point in it. Just a stinky mess as far as I'm concerned. Some drip, some don't. Stories of oil soaked turboes and oil filled intercoolers are, IMO, mythological bs.
The 'provision' you speak of is indeed for the crank case vent.
Old Nov 7, 2007 | 08:09 PM
F250_'s Avatar
F250_
About the condensation. I was really concerned about that for a little while, but am no longer. After running my "trap" under the cab for several months during cold weather, I collected about 3-4 ounces of black oily stuff from the trap. I sealed the jar and let it sit to see how much moisture condensation there was in that oily stuff. After letting the jar sit for four months, completely untouched the entire time and never moved... absolutely NO water... it's all oil.
Point is, if you run the hose up and over the MC, any condensation you get will be nothing more than oil, and it won't hurt anything to have that run back down the hose into the crank case.
Old Nov 8, 2007 | 01:33 AM
ernesteugene
Originally Posted by F250_
... Point is, if you run the hose up and over the MC, any condensation you get will be nothing more than oil, and it won't hurt anything to have that run back down the hose into the crank case...
Running the hose uphill increases the CC pressure a little, and the stuff that condenses and runs back into the doghouse is a little corrosive and somewhat gunky, and it might tend to gum up the mesh over time, which also increases CC pressure.
The point in favor of a CCV mod is that without it you can blow off the CAC boots which happened to me several times while towing long mountain grades. But even the least restrictive CCV mod increases CC pressure from a negative 4" or so to a positive 3", and this can be enough to cause other problems that are even worse than blown boots.
I think that anyone with a CCV mod should have a gauge to keep tabs on their CC pressure. By measuring the amount of blow by you get an instant status check on the health of your engine. Also, if a beetle bug should crawl up your vent hose and get stuck, you'll know about the problem immediately instead of finding it when seals start leaking.
Old Nov 8, 2007 | 11:43 AM
F250_'s Avatar
F250_
I understand what you're saying Ernest, but it is very hard for me to imagine that a difference of only 2-inches of open area will make any significant difference in pressure (if it were going against a water column, that's one thing, but open area is another altogether). I know that science says that increases in elevation result in increased pressure on an absolute basis, but.... I've already stated my opinion on the significance of this increased pressure.
Also, given the complete lack of condensation during warm months taht I've collected some 6' downstream of the doghouse in my trap, and the 3-4 ounces collected in winter months, I also find it hard to believe that this uphil climb made by my hose for only the firs t8-10 inches right off the engine will provide enough time for any significant condensation at all. Yes, again, I know that on an absolute basis it will happen, but if I'm only collecting 3-4 ounces at a much cooler position downstream of the doghouse, and those 3-4 ounces being collected over a period of some 6-8K miles... the amount of real condensation at the higher temperature position within 10 inches of the doghouse cannot be significant to any degree.
Old Nov 8, 2007 | 04:01 PM
ernesteugene
...I understand what you're saying Ernest, but it is very hard for me to imagine that a difference of only 2-inches of open area will make any significant difference in pressure...
In general, my philosophy is that every little bit either helps or hurts, even if it's only a small amount.
... the amount of real condensation at the higher temperature position within 10 inches of the doghouse cannot be significant to any degree...
However in this case, I'm pretty sure it's much more than a small amount. The only reason I've ever seen given for running the hose up and over is so that most of the condensation runs back into the doghouse. Most of the hot vapors condense in that 10" uphill run of cooler hose just like in a still. Hot Vapor+Cold Hose=A lot Of Condensation! That's probably why you don't collect so much down stream.
Old Nov 9, 2007 | 02:36 AM
Izzy351's Avatar
Izzy351
To address an earlier post, oily boots and I/Cs is definitely *NOT* mythical BS. The reason I found this site is because my boots were nasty oily and the orange ones were leaking and causing oil to collect in the valley and eventually drip down the back of my engine. When I did a search for 7.3 oil leak or something similar, I found this site. Now that I have done the CCV (my first mod!!), no more oily boots and I haven't had any oil drip from the end of the hose. Mine is run back to where the exhaust is -- no problems with smells or anything like that, and the little bit of smoke goes unnoticed since the exhaust is right there.
Old Nov 9, 2007 | 06:14 AM
greedy737's Avatar
greedy737
My buddy has an international truck, the CCV vents straight down the back of the motor. A little smoke hardly no smell, unless you stick your nose near it. And no problems, at 126,000 mi. on it!! I have mine going up over the brake thingy and straight down 2.5' ..
Old Nov 9, 2007 | 07:44 AM
F250_'s Avatar
F250_
I don't want to argue over the issue, Ernest, but my observations are in direct contradiction to your above statement. If it were only as simple as what you've described, I would actually collect more condensation downstream in the summer months than in the winter due to the smaller deltaT between ambient and vapor temperatures in the first 10" of hose. In other words, in order to accomplish the same amount of condensation, more "time at temperature" is required when the delta gets smaller... it's simple thermodynamics.
Let me also add that my observations are that with my Schaeffer oil, I am getting more vapor out the end of the hose than I ever did with the Amsoil oil, which would also lend itself to an increase in captured condensate in my trap if it were a simple matter of what you described above.
Old Nov 9, 2007 | 08:20 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
I was waiting for someone to pick up on that point. Joe's right, oily boots and a fouled I/C ARE the end result of not doing the CCV mod. In fact it's what pushed me to finally do it. I couldn't stand having that oily, gooey mess all of everything and having to wipe things down before I stuck my hands into the engine compartment. Since doing the CCV mod and detailing my motor everything is nice and clean.
By the way good to see you on, Joe!
Old Nov 9, 2007 | 09:48 PM
mudmaker's Avatar
mudmaker
Does anyone have problems with condensation freezing in the tube causing problems? I am wanting to do this mod on my X, its boots are a filthy with oily residue. The funny thing is my pickups tubes are much cleaner than the X and it has nearly double the miles on it.
Old Nov 9, 2007 | 10:29 PM
  #28
Tenn01PSD350's Avatar
Tenn01PSD350
Well, if you read this thread you have your answer. Either way will eliminate the oil going into the turbo and IC system. The point of contention here is whether running the tube up from the doghouse leads to problems. I don't see a problem either way. If it goes up, then the condensate will leak back down onto the VC. Whoopdidoo. So the moisture causes damage? The CC is not sealed to the environment so there will be condensation anyway when it cools.
Now to answer your question, yes, there have been posts here of the CCV mod hose freezing up and causing a problem, but I am not sure how unless you leave a long low spot in the run for it to collect in. Even then, with a big enough hose and long enough run, it would not clog up, rather evaporate as the truck is run. Bottom line, avoid a big low loop in the hose if running out the rear by the axle.
Old Nov 9, 2007 | 11:06 PM
  #29
bigtorque's Avatar
bigtorque
humm, now i have a different story,turned the elbow too the drivers fender and ran mine straight down to the frame rail with only about 4 ft. of hose, and it dumps at the frame under the drivers door, and i do get drips, and loads of oil fume from it, (smokes like a chimney) i noticed tonight that when i get on it hard, it really blows as i could see it in the guys head lights behind me and it wasnt black.
I however have loads of power, any one have an idea why some seem to smoke more than others. TYPES OF OIL MAYBE!!!!!!!!!!!
Old Nov 9, 2007 | 11:41 PM
  #30
Tenn01PSD350
All I can say is the colder it gets, the more smoke I can see. I have also noted that others have had some different observations with different grades of oil.
