I've got a rattle in my 2001 F150 Super Crew. The noise is in the dash on the passenger side. I've had it in 5 times. They've been able to reduce how often I here it and how loud it is, but I still here it at highway speeds. Has anyone experienced this type of a noise? If so, what was done to eliminate the noise? What have people done to eliminate noises in the dash?
Thanks for any help!
hey my name is Ken I own a 2001 supercrew and i work for Ford. if have have a rattle question e-mail hlew@ford.com he works at
th michigan truck plant and maybe able to hekp you stay in contact.
my 2000 extended cab f-150 was making the same type noise. like some thing rattling in glove box area only at highway speeds. i tightend everything up that could rattle.still did it. took the bug sheild off and it would quit making the noise. put sheild back on it would start up. try that. i never did put it back on rattle was two anoying. let me know if that was the problem
I owned a 97’ F150 SC and not have a 01’ SC, I notice the rattle in both trucks. It just started in the new one. I think my rattle comes from the cover on the passenger side dash (oval shaped) Remove this and see if you can locate the source, it is held in by clips and can be remove and replaced. I notice the rattle when I travel down a dirt road that has the wash board effect. If you can find a road like that it may be safer to locate the rattle than at high speeds.
