I have a Superchips programmer, i keep my truck tuned most of the time...
I am experiencing power loss noticeable to me only when pulling my trailer, i always pull it when returned back to stock tuning.
before I brought the truck to the repair shop last night to leave it with them, i returned her to stock, but checked the codes first, i had the "p1249- Wastegate Failed Steady State Test" code. I didn't clear the code, but it is not showing any codes for them this morning, they called me and said they can't find anything wrong. I told them about the code i had, and they are researching further.
My question is would the wastegate problem cause this loss of power, and would it show up all the time, or in stages...I have 18lbs of boost pressure the tech said.
18 psi on a stock tune is ok.
I'm thinking that code was set while you were driving with the tune installed.
Try towing your trailer in stock tune and see if that code comes back.
How can a wastegate fail? It's spring loaded in the closed position, and requires boost pressure to open. Grab the actuator rod and push it in the direction of the turbo. It shouldn't move unless you grab it with vise grips and push pretty hard.
the springs do get weak,I could push my old one open fairly easy by hand
I mentioned this in another thread about how my turbo is in the beginning stages of doing this. For now I have disabled the WG so it will hold the lever shut hard against the valve seat and put off losing the valve head.
It's pretty easy to see how you would lose boost without the valve in place.
This turbo is off of a VW 1.8t gas engine.
The question was intended to be rhetorical! Of course anything and everything can fail, I was trying to point out some of the ways the PSD wastegate might fail, and checking for spring tension using the test I suggested is the first place to start. Sometimes the retaining clip on the actuator rod comes falls off, and the rod comes loose from the wastegate valve.
As a "fail safe" to prevent excessive boost, the wastegate control system is designed so that if the control solenoid fails or it loses its PCM control signal, the full level of intake manifold boost is routed directly to the actuator nipple.
I once did an experiment of hooking up a rubber hose to directly connect the fitting on the intake manifold to the nipple on the actuator. The maximum boost you can get is about 10 to 12 psi at WOT. This test will check the actuator diaphragm action, and the spring tension. If a truck doesn't have a boost gauge, this is a good SOP way to see if the waste gate control system is working. If it feels the same with the hose bypassing the solenoid there's a problem with the control system.
What surprises me is the fact that nobody has marketed a higher pressure wastegate control canister that is set, for instance, at 25 psi.
When I installed the hypertech and larger exaust and K&N, I started getting that error. I then installed a BD wastegate actuator and problem has been gone for 75k, never rearing its ugly head again. They say the original waste gate won't hold up to all the mods, spring gets weak and it flops in the (turbo)wind.
