engine codes because of wastegate actuator diconnect?
While the truck is getting a new tranny installed, the tech gave me the following codes
1249---wastegate control valve performance
p1247 -turbo boost pressure low
What is going on? I pulled that line like everyone says to keep that wastegate actuator closed longer and why am i having this problem???? anyone with suggestions?
OK I may have jumped to a conclusion too early, I never reset the codes after the wastegate actuator arm came off...so after he pluggs her all back in he will reset her and let me know...Also I fixed a broken manifold bolt a while back an the exhaust tick went away for a while and now I have a leak back...hmm cant find this one easy enouph.
Originally Posted by ckeener
can any one help me on a 2001 7.3 showing a p1247 and a1248 with an auto. I have low power and cannot reach speeds over 60 any advioce.
The 1247 is low boost and the 1248 is no boost detected.
I'd go back to post #2 in this thread by mech2161. Sounds like a failed MAP (maniold absolute pressure) sensor.
ExPACamper
10-15-2015 06:46 PM
dirtroaddevil
10-27-2003 07:10 PM
