Sponsored by: Auxito
Engine swap
Old Nov 6, 2007 | 09:18 AM
prestonavy31's Avatar
prestonavy31
Engine swap
owner on 99 f150 stepside 4x4 v-6 manual tranny. does anyone no if the 4.2 ltr v-6 can be swapped out or a 4.6 or 5.4 v-8, and will the v-8 work with stock manual tranny
Old Nov 6, 2007 | 11:06 AM
Big Bad's Avatar
Big Bad
The 4.2L V6 shares it's bellhousing bolt pattern with the 302/351 Windsor V8s.
The Modular bellhousing pattern is different, so the trans won't work.
Old Nov 6, 2007 | 11:12 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD
how is that possible...the M50d comes behind the 4.6l and the 4.2 l?
Old Nov 6, 2007 | 11:21 AM
Big Bad's Avatar
Big Bad
Different bellhousing.
Old Nov 6, 2007 | 02:11 PM
BURNSTOUGHFORD
U are sure?
Old Nov 7, 2007 | 09:44 AM
Big Bad's Avatar
Big Bad
The bolt patterns are different. 100% positive.
The 4.2L is a Canadian Essex engine which shares the bellhousing pattern with the 302/351 SBF. Fact.
Modular bellhousing pattern is unique. Only very early production Modulars (1991 - 1992) shared bellhousing patterns with the Windsor V8s.
All of this information is readily available. Found this after a 1 minute Google search: http://manualtransmissionservice.com/tech.aspx
There are 4 bellhousing patterns available for the M5OD.
1. 4 cylinder
2. Cologne V6
3. Essex V6/Windsor V8
4. Modular
A 4.2L M5OD trans will not bolt up to a Mod motor.
Old Nov 7, 2007 | 10:07 AM
BURNSTOUGHFORD
Cool...good work...learned something new...
Old Nov 7, 2007 | 10:10 AM
prestonavy31
so a 351 windsar will bolt to the m5od
Old Nov 7, 2007 | 11:29 AM
Big Bad's Avatar
Big Bad
Yep. But you'll run into numerous issues swapping a 351W into your truck.
Old Nov 7, 2007 | 01:10 PM
prestonavy31
i'm sure with different weight and electronics
Old Nov 7, 2007 | 06:35 PM
Dustin1690's Avatar
Dustin1690
Also many say the 351 is too powerful for the M5OD could be true they never put a manual behind a 351 or a 5.4l V8
luisfer8724
Mar 11, 2010 01:14 PM
bajacustoms951
Engine Swaps
Oct 4, 2005 05:08 PM
parks911
Apr 18, 2004 12:23 AM
