Timing?
Old Nov 5, 2007 | 05:16 PM
1Saint's Avatar
1Saint
Timing?
Hi
Can anybody tell me what the timing is suppose to be set at on a 1987 6.9 with an ATS 085 turbo? I have the paper work form when the previous owner had turbo installed that says the fuel was turned up and the timing advanced but it doesn't say what it was set at.
Thanks Again
Old Nov 5, 2007 | 08:22 PM
PLC7.3's Avatar
PLC7.3
It should have been set originally at......
6.9IDI ( Navistar method ): 6-7 degrees BTDC
Old Nov 5, 2007 | 08:52 PM
KJLYPW's Avatar
KJLYPW
After 83, they are all the same. 8.5 * BTDC using the pulse method, at 2000 rpm. My Kent Moore timing data sheet also calls for 5* +/- 2 at 1400. If you have acess to the luminocity type of set up it is set up at ATDC, but I don't have that info.
Old Nov 5, 2007 | 09:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle
With the luminocity probe you are looking for 1 to 1.5 degrees ATDC for the stock setting.
I would shoot for as close to TDC on the after side as I could get it.
Old Nov 5, 2007 | 11:56 PM
1Saint's Avatar
1Saint
Thanks guys.
Is the reason for advancing it to just after TDC due to the turbo? Also is a 1 to 1.5 degree ATDC luminocity setting the same as 8.5 degree BTDC with the pulse method? And what is the Navistar method?
Old Nov 6, 2007 | 09:03 PM
Dave Sponaugle
The pulse method senses the fuel in the injection line going to the injector as the pressure increases.
The luminosity probe senses the fire starting to spread through the pre combustion chamber.
Both readings are close to the same, but the degree reading is compensating for where the trigger is detected.
The turbo has little bearing on where you want the timing set.
The closer to TDC the fuel starts pushing against the piston on the combustion stroke, the longer it can push before the piston reaches BDC and the exhaust valve opens.
Old Nov 6, 2007 | 09:21 PM
1Saint's Avatar
1Saint
Thanks again Dave.
bduemig
Aug 9, 2012 12:56 AM
eatont9999
Mar 13, 2012 04:38 PM
Perdue
Dec 13, 2011 02:54 PM
voyeurcouple2
Dec 21, 2007 06:27 PM
Lushman
38
Mar 29, 2006 05:36 PM
