Whats the little screw-in switch called on the bottom, back side of the fuel filter canister. It has one wire plugged into it. Mine's leaking and I don't know what its called. Thanks.
Fuel Filter Water in Fuel Control Switch, not the part in the bowl
(Ford) F4TZ-9J294-A (94-97)
(International) 1821712C1 (In harness behind HPOP reservoir pass. side) Fuel Filter Water in Fuel Sensor Probe, 94-97, the part in the bowl
(Ford) F5TZ-9J294-A
