Oxygenated alchohol
Old Jul 8, 2016 | 02:33 PM
fatfenders56's Avatar
fatfenders56
Oxygenated alchohol
I just spent some time in Calif using the oxy-alky stuff they call fuel. Had to switch to 93 octane while I was there to even get my truck to run on it. When I got home 1300 miles later all of the seals in my fuel system were leaking and had to be replaced. I am suspicious of the gasahol thing. Does anyone have any solid information on using this stuff in older engines?
Old Dec 5, 2016 | 05:30 PM
monckywrench's Avatar
monckywrench
Avoid alcohol on older engines. I don't care for it in newer engines either. Except for cost there's no reason to burn alcohol except to make the farm lobby even wealthier. Alcohol absorbs moisture and is horrible for carbs.
Old Dec 9, 2016 | 02:01 PM
Beechkid's Avatar
Beechkid
In short- yes...MTBE ....very corrosive to conventional hoses, seals, O-rings, etc....there are actually warnings posted on all of our pumps about it (you probably missed it) but typically, if its an EFI system of for EFI system as far as parts go, you are typically ok.
hivoltj
Nov 19, 2018 06:51 AM
Bulldawg1081
Sep 10, 2018 01:58 AM
lance65
Dec 3, 2006 09:39 AM
RhinoScores
1978 - 1996 Big Bronco
Jan 8, 2005 07:57 PM
