Fuel Filter Questions
Old Nov 5, 2007 | 02:56 PM
aklim's Avatar
aklim
1. Why am I paying $36 for a fuel filter from Ford when I can get it for $21.42 or a Lubrifinder one the local International shop uses for $16.67?
2. Seems like it is pretty foolproof to install, right? If it doesn't spray fuel all over the world in the first 30 seconds, you are golden. Am I correct?
3. I am using the wrench that I normally use to take off the oil filter. I just put it on the top of the lid and turn. Is that OK or does anyone see any issues with doing it that way?
TIA
Old Nov 5, 2007 | 03:02 PM
ron's power stroke's Avatar
ron's power stroke
i get mine at Napa for 20 bucks.. some guy's have been getting them on line for 16......as long as you dont crack the top you can use any thing you want to take it off or put it on..i never had to use wrenck..always take mine off and put it on with just my hands..no leaks so far..
Old Nov 5, 2007 | 08:00 PM
F350-6's Avatar
F350-6
1. I have no idea why you are paying more money to the Ford Dealer.
2. The general consensus seems to be a racor filter (OEM) seems to be best, but they can be had for much cheaper than Ford charges.
3. An oil filter wrench works just fine, but one that has a swivel joint that will allow you to turn the handle 90 degrees works better.
Old Nov 5, 2007 | 08:06 PM
aklim's Avatar
aklim
1. Because I didn't know better till I saw the instruction sheet that had Navistar written on it.
2. So Racor makes it for International who sells it to Ford?
3. That I have. Just didn't know if I would break the cover doing that.
Old Nov 5, 2007 | 08:13 PM
F350-6's Avatar
F350-6
Yes Racor makes it for International/Ford. I've used that wrench in my 02 for the last 235,000 miles with no cracked lid so you should be fine.
Also, if you buy filters online, or at some local shops, there is a price break when you buy 6 at a time. Of course that's easier for the high mileage drivers.
Old Nov 5, 2007 | 08:22 PM
aklim's Avatar
aklim
Thanx. I'll do that
rodneywar
Jun 24, 2012 10:10 PM
23larry24
Aug 17, 2011 10:19 AM
bhmudder11
Jun 15, 2010 11:41 AM
adambomb
Aug 28, 2009 02:21 PM
