Bypass filter
Old Aug 16, 2011 | 06:16 PM
23larry24's Avatar
23larry24
Bypass filter
I am in the process of putting together my bypass filter set-up and was wondering if it would be acceptable to use a fuel filter for this set-up. Fuel filters seem to have a better micron rating. I was thinking of the donaldson p551311.
Old Aug 16, 2011 | 07:28 PM
SpringerPop's Avatar
SpringerPop
I don't think I would use a fuel filter to filter oil. You want something that passes the oil through it slowly to achieve the finest filtration.
I have a home-made bypass filter on mine, and if you're interested, there is a link to how I did it in my sig file, below. Just click on it.
Pop
Old Aug 17, 2011 | 08:14 AM
rufushusky's Avatar
rufushusky
Fuel filters are rated lower usually and are rated differently, a fuel filter is an open cycle and are therefore rated at a single pass. While hydraulic and oil filters are mult-pass rated. I would not use a fuel filter cause the media may not like the 180-200* oil and it would be harder to restrict the flow to keep from spiking oil pressures.
Springerbob's set up is one of the better ones. I myself run the donaldson ELF7405 which has a bypass built into the filter and bumps total oil capacity up to 16 quarts even.
Old Aug 17, 2011 | 10:13 AM
SpringerPop
Now, THAT is a Big Honkin' Filter!
See: https://www.ford-trucks.com/forums/1...l#post10579710
Pop
Old Aug 17, 2011 | 10:19 AM
rufushusky's Avatar
rufushusky
Pop
Yes sir it is a massive filter.
But at 25 bucks a pop, really isn't too bad on wallet.
Mouse4x4
Apr 3, 2024 03:04 PM
RKern
Oct 12, 2010 01:05 PM
n20
Oct 13, 2009 12:17 PM
PSNut
Jul 19, 2006 04:19 PM
rmilchman
Jul 23, 2005 04:44 PM
