Sponsored by: Auxito
fuel filter
Old Nov 5, 2007 | 01:54 PM
tractor_boy's Avatar
tractor_boy
fuel filter
Does anyone have any links showing how to change a fuel filter on a 2003 f150 with a 5.4L? I bought one and was wondering if there were any tricks in doing this.
Thanks for the comments
Old Nov 5, 2007 | 02:04 PM
KingRanchMan02's Avatar
KingRanchMan02
You need a special tool to release the quick connect lines from the filter. You can pick up a package of different size tools from any auto parts store. Place the tool around the line. Slip the tool into the connector on the fuel line, pushing the tool and the line towards the fuel filter. Hold the toll in and pull the line off. Good luck!
Old Nov 5, 2007 | 02:09 PM
tractor_boy
I went to CarQuest, but they didn't have any tools for the filter. I bought a filter there though and 2 plastic pieces came with it. The guy there said just to use a very small flat head screwdriver to take it off. They just gave the plastic pieces just in case the ones on the fuel line break off. Otherwise you can use the original ones on there. Does this guy sound right at CarQuest or should I go somewhere else to get the disasembly tool?
Old Nov 5, 2007 | 02:13 PM
KingRanchMan02
I would try a different auto parts store for the tool. I know that Autozone carries them. I would expect that Carquest would too but maybe I'm wrong about them.
Old Nov 5, 2007 | 04:04 PM
mdpitt's Avatar
mdpitt
I would recommend against doing it without the tool as there are three hooks that hold the filter in place and one flat head screw driver could be challenging and damage it, then your into big bucks, good luck with it I got my tool at a Napa store, good luck with it,
Old Nov 5, 2007 | 04:16 PM
RedDragon777's Avatar
RedDragon777
yeah just go to autozone and ask for the tool to disconnect fuel lines and they should be able to help you
Old Nov 5, 2007 | 05:28 PM
steve(ill)'s Avatar
steve(ill)
the screw driver is to remove the two plastic external clamps. you need the slip on tools the guys are talking about to slide over the gas line, into the filter tube and relieve the internal ears or "teeth".
john fin
Dec 21, 2011 12:28 PM
sswebber
Nov 3, 2010 06:09 PM
fast70
Apr 27, 2010 08:15 PM
numocystic_10
16
Sep 29, 2008 07:08 PM
lpbaca
Jan 5, 2005 01:40 PM
