Rear Main seal
Old Nov 5, 2007 | 12:54 PM
glennp's Avatar
glennp
Rear Main seal
I need to replace my rear main seal on my 1967 F100 and looking for a diagram and general instructions. I did one years ago on a chevy. Any suggestions?
Old Nov 5, 2007 | 01:05 PM
blue68f100's Avatar
blue68f100
It's easier to pull the engine. It can be done in the truck but very difficult since the transmission is connected. Most of the new seals are 2 piece molded rubber seals. And some are 1 piece seals. You don't see the rope seals much any more.
Is this a 6 or v8.
Old Nov 5, 2007 | 01:26 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
As original: 1967 F100
The rear main seal on 240/300 I-6's is one piece. The 352 rear main seals are two pieces.
Old Nov 5, 2007 | 03:43 PM
jowilker's Avatar
jowilker
Glen, What engine are you referring to. While the FEs are heavy rear leakers it is the intake seal not the main seal that needs replacing.
The I-6s are a different matter.
John
Old Nov 6, 2007 | 12:41 AM
Bookman's Avatar
Bookman
What do you mean by intake seal? If it is leaking at the rear of the housing isn't it the rear seal?
Old Nov 6, 2007 | 02:59 AM
NumberDummy
He is refering to the rear seal of the intake manifold, which comes as part of the intake manifold gasket set: C3AZ-9433-G.
Old Nov 6, 2007 | 04:23 AM
jowilker's Avatar
jowilker
Bookman, Clean the rear of your engine to watch where the oil is coming from. The rear mains can leak on a FE, but usually not. They are a real pain in the butt to change so you want to make darn sure that is what is leaking. Actually either is.
Intake manifolds on the other hand are known for leaking and I think because of installation habits that it leaks in the rear more than the front.
Bill as usual, has supplied the part number. Felpro makes good gasket sets, available most anywhere. Some are just using RTV and no cork. RTV needs to skin over before replacing the manifold to it.
John
Old Nov 6, 2007 | 07:52 AM
blue68f100's Avatar
blue68f100
Glen, I hope it's a intake leaking and not the rear main as you asked. The intakes are prone to leaking as every one has hit on. These cast iron intakes weight in the 90# range. So use a cherry picker to handle it or someone to help you. You must set these straight down without distrubing the front and rear seal. Hard to do if your by your self. The bad thing is that you must remove the rockers and pushrods to get the intake off.
Old Nov 6, 2007 | 08:58 AM
Danger_Dave's Avatar
Danger_Dave
John
yep them rear intake seals are a son of a gun, i had a fun time getting mine not to leak after replacing my manifold.
Old Nov 6, 2007 | 06:16 PM
Bookman's Avatar
Bookman
which of the Edelbrock manifolds produce more low end and or power to these motors?
robjs111
Oct 2, 2011 10:28 AM
DT 466Man
Apr 29, 2005 10:41 PM
fearfactory
Jan 19, 2005 05:23 PM
a9464
Jul 24, 2003 08:08 AM
adroc104
Apr 3, 2003 08:27 PM
