rear main seal
Old Jul 17, 2003 | 11:08 AM
a9464's Avatar
a9464
rear main seal
I have a 56 with a V8 and I need to replace the rear main seal. My local parts house offers two differant ones. A traditional rope seal and a molded rubber seal. The ? is which is better, easier to install, etc. Thanx Arnie
Old Jul 17, 2003 | 08:54 PM
57_ford's Avatar
57_ford
rear main seal
I think I would try the new rubber style. I have never installed one. But I have installed the rope type in frame and I would not want to do it again. You will also need a special tool to install the rope type.
Old Jul 17, 2003 | 10:59 PM
pcmenten's Avatar
pcmenten
rear main seal
The rubber rear main seal is a relatively new part. It's the way to go. The rope seals dry out if they're allowed to sit for too long. Then when you start the engine with the dry rope seal, it scorches before it ever gets re-wetted with oil. Leaking again. The neoprene seal does not have that sort of problem. Use that one.
Old Jul 23, 2003 | 07:58 PM
atticmole's Avatar
atticmole
rear main seal
I'm not sure but I think that the 292 Y block uses the neoprene seal, but that the 312 Y block still needs to have the rope style seal. Pretty sure I read that here. Do you know what V8 you have? Gonna have to do mine before long, let me know how it goes. Larry
Old Jul 24, 2003 | 08:08 AM
charliemccraney's Avatar
charliemccraney
rear main seal
Go to www.ford-y-block.com. They have molded rubber rear main seals for the 292 and 312. They have a lot of other neat stuff for Y-Blocks too.
pikerspiker
Oct 22, 2009 06:24 AM
grover
Jul 15, 2005 04:46 PM
DT 466Man
Apr 29, 2005 10:41 PM
fearfactory
Jan 19, 2005 05:23 PM
adroc104
Apr 3, 2003 08:27 PM
