More towing questions
Old Jul 5, 2002 | 11:59 PM
91paint pealer's Avatar
91paint pealer
How well do yall think my 300 with a a4od and 8.8" rear would do pulling a 25' boat up and out of the water? Will a ball on the bumper do or will I need a hitch.
Old Jul 6, 2002 | 09:28 AM
DrFord's Avatar
DrFord
what kind of boat is it? the motor has plenty of grunt to pull it out of the water. the weight of the boat would be the determining factor on wether to hook to the bumper or get a hitch.
p.s. if the truck is only 2wd be sure to have good to decent tires. especially if you will be using the boat in the winter.(icy ramps are slick)
Old Jul 7, 2002 | 12:16 PM
Vampiro's Avatar
Vampiro
the 300 6 will have no problem. if it's a fiberglass boat you might need a hitch. aluminum can go right on the ball. but ewither way id still get a hitch
Old Jul 7, 2002 | 12:58 PM
tetraruby's Avatar
tetraruby
Like already posted, the 300 will pull just fine. My concern, if I were you, would be how good your drivetrain is. Meaning, what rear end ratio are you running? Do you have a tranny cooler installed? Is your truck half ton, 3/4 ton? The lighter truck may not be the best for braking. You need to find out how much the boat and trailer weigh.
Old Jul 7, 2002 | 11:21 PM
91paint pealer
thanx guys i guess i'll go with a hitch, for safety's sake
Old Jul 8, 2002 | 06:50 AM
Stephens's Avatar
Stephens
Oh yes, class III hitch for sure. I pull a 20 ft fiberglass center console boat without any problems, except my throw out bearing gets to chattering. My boat hits the scales at 2600lbs. A fiberglass 25 ft would be over 4000 lbs and alot more if its an inboard. That's heavy enough to require brakes on the trailer.
Note: if you don't have electric brakes, be extra careful. That load will more than double the distance you need to stop.
Old Jul 9, 2002 | 09:37 AM
IBen17's Avatar
IBen17
Anyone know what the weight rating for the bumper hitch is?
Old Aug 22, 2002 | 12:37 PM
GeneStoner's Avatar
GeneStoner
Old Aug 23, 2002 | 10:02 AM
Stephens's Avatar
Stephens
For ball park purposes, as I recall, the bumper is rated for 300lb tongue weight and 2000 lb towing weight. If you really want to use the bumper, you can reinforce it. Weld in some plate steel around the ball and then weld some stiffners (angle iron) from the frame to the bumper. I did that on a Chevy 3/4 ton and pulled a 3 weheel trailer with bush hog.
I see alot bumpers all bent out of position from guys towing too heavy a load on the stock bumper.
Old Aug 23, 2002 | 10:06 PM
falcon26's Avatar
falcon26
I have a 94 F-150 XL and the bumper is rated at 5000 lbs. It is a class III. I've pulled 3500 lbs. with it without any problems, but would like to have a hitch to bring the front of the trailer down and level. Other than that, I really don't see any real need to buy a hitch yet. They also make box type receivers that bolt onto the bumper for this purpose.
Old Aug 24, 2002 | 09:52 PM
MustangGT221's Avatar
MustangGT221
Previous poster is correct, the ford bumpers are rated to be a class III, which is 5,000lbs right? Good enough for what that truck can tow. The rear end ratio is what will be a big factor, and the overall weight of the trailer. You can get away with 3.55s on 235/75/15 tires. I have 3.55s and 32" tires, which brings the ratio down to about 3.15, and I towed a heavy boat, around 3500-4000lbs and it struggled, I wouldn't do it often (it was only about 75 miles) because it's a lot of extra strain. If you have 3.08s, and plan on towing this often, than change gears.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 25, 2002 | 06:45 PM
krooser's Avatar
krooser
Old Aug 27, 2002 | 02:39 PM
Stephens's Avatar
Stephens
I try to not refute anyone's post on the site and for sure not in a way that might offend anyone. But today I saw a 93ish F150 with the bumper all turned down and it made me think again about the towing rating on the older FOrd 150 bumpers. So, I consulted my owners manual for bumper rating. According to MY FORD 1988 manual, they rate the bumper to 2000 lbs and recommend a "frame mounted hitch" for any weights above 2000lbs. I tow a 20 ft Proline and installed a class III hitch. I'd love to hear back how its working out for you with towing your 24ft'er. Maybe someone rated the bumper a class III, but Ford didn't rate mine that way.
Dogmann
Modular V10 (6.8l)
45
Jul 25, 2015 12:12 AM
Jarryd
Feb 3, 2015 12:38 AM
dferrell5
30
Jan 25, 2014 01:26 PM
kupiec20
Apr 25, 2010 09:32 PM
r0n1n
Jul 8, 2005 10:25 PM
