8 lug conversion for 8.8
I can't tell you if there is or not, I would lean toward there not being a conversion though. The 8.8 is a decent axle but if you're pushing it enough to actually not need TTB then you may as well step up to the sterling rear for peace of mind as well as affordability. Sterling rears are cheap and you could readily find one with your gear ratio that would cost less than changing shafts and outers on the 8.8.
If I were you I would get super duty axles that way you get newer parts, solid axles (even on f250's), and 4 wheels disk brakes. And like previous stated you could get both axles easily from one truck. And heck you could find a totaled out one and buy the while thing and maybe make some of your money back in the end.
f150longbed
18
09-15-2013 10:37 AM
jmteam6
07-09-2006 12:13 PM
todder53
02-08-2004 05:04 AM
motorhead_83
04-24-2003 02:11 AM
