Sounds like a CAM.
Old Nov 5, 2007 | 06:55 PM
c00nhunterjoe's Avatar
c00nhunterjoe
for the last time gremlins are in gassers, widgets are in diesels........
and you can get the sensors from autozone
http://www.autozone.com/N,15700218//...eResultSet.htm
Old Nov 5, 2007 | 08:02 PM
jboard's Avatar
jboard
Ok thanks guys I just ordered one well see it it works.
---------------Jeremy
Old Nov 6, 2007 | 04:26 PM
glasseater's Avatar
glasseater
well my truck was fine today idk maybe i had a bad couple tanks of gas.... just went 235 on 1 tank by the way!! hoping for at least 245 on this next one!!!
Old Nov 6, 2007 | 05:16 PM
jboard's Avatar
jboard
I usually switch tanks at 1/4 tank mark around 300 miles.
-----------Jeremy
Old Nov 6, 2007 | 05:24 PM
PAVEMENTMAN's Avatar
PAVEMENTMAN
Mine Does This But Mine Is A Stick Shift Any Ideas Here??????
Old Nov 6, 2007 | 05:26 PM
PAVEMENTMAN
Mine Runs Fine Cold It Just Starts Loping Like It Has A Cam In It When It Gets Warm Anyone Have Any Ideas Ita A 5 Speed Manual Tranny.
Old Nov 6, 2007 | 05:35 PM
Action4478's Avatar
Action4478
If you aren't low on oil & are not due for a change ...You most likely have a HP system oil leak(internal)..IPR o rings Or an in jector Oring...
Could have an injector poppet issue also...
thanks to Swamps Diesel site.
How to check if my HPOP is good
There are 2 ways to measure the oil pump's performance.
If you have access to a scantool, hook it up to the trucks OBD connector, and go to the "datastream"...scroll through the sensor values, until you find ICP (or injection control pressure)...this is your HPOP's "oil pressure".
***NOTE: if you are running any kind of "box" such as the "Edge EZ" or the "Banks Six Gun" you either have to remove the aftermarket jumper harness/plug at the ICP sensor, and reconnect the factory harness by itself. If you are running a home made "10k mod", etc...which plugs/taps into the ICP sensor wires (or connector pins), you will have to remove it as well, or proceed with getting the parts together to run the mechanical gauge, as the scantool will not receive accurate data from the ICP sensor if its signal is being modified from any one of thes "ICP foolers".
To test the HPOP's output, you will be looking on the scantool for the line labeled "ICP" and it's units should be in psi not volts. Some scantools measure ICP in kPa (kilopascals) which you can convert to psi after you take your measurement in kPa.
1kpa = 0.145psi
(for example 19,310kPa = 2800 psi)
Put your chip in its' highest setting, and go out on the interstate (while having someone watch the ICP value on the datastream) and start at about 60mph...
FLOOR the pedal, and stay in it, 100% from ~60-90mph...what you're likely to see (on the scantool) is that the ICP will spike up rather quickly, to 2800-3000psi or so, and then the longer you stay in the pedal...the ICP will slowly drop and drop and drop...the ICP will eventually stabilize (stop dropping).
WHERE the ICP levels off can be some indication as to the condition of your HPOP.
If your truck can maintain 2800+psi then you are one of the FEW folks that have a terrific HPOP.
I would estimate that 90% of the Power Strokes can only maintain ~2200(+/- 200)psi of HPOP pressure, or ICP...5% are above 2600, the other 5% are below 1900psi...
depending on how low (or high) of ICP you are able to maintain will greatly affect which model of injector I would recommend.
If you don't have access to a scantool, then go to your local hydraulic supply house, and have them make you up a mechanical gauge. You might spend $60 or so on high pressure hose, fittings, and a quality 0-3500psi liquid filled gauge....but having this hose available for future diagnostics might be more valuable than you think.
The hose which you will need will need to be about 40" long, rated for (minimum) 3000psi working pressure (12k psi burst rating!) with the gauge on one end, and a #6 female JIC swivel fitting crimped onto the other.
You will also need an individual fitting to screw into the head to go from the head to the hose.
This single fitting will be a 90degree fitting # 5 "male boss" (sometimes called # 5 o-ring) on one end of the 90, and a # 6 male JIC on the other end of the 90. Our local hydraulic shop would label such a fitting as 5MB-6MJ90
"JIC" is nothing special...it's just 'hydraulic talk' for a 37degree flare fitting...standard hydraulic stuff here...nothing rare by any stretch.
Looking at the top of (either) cylinder head, you'll see the factory stainless braided oil lines (one to each head) then you'll see a few bronze colored plugs... (Engine off, of course) Using a 5/8" wrench, remove any one of the bronze plugs, and install the 90deg fitting into the hole. (save the plug for reinstallation , after testing). and the O-rings are reusable, unless brittle, cracked, etc...
The single 90deg fitting will have a "jamb nut" on the O-ring side...screw the fitting into the head, "aiming" the 90 away from the turbo, intercooler pipes, etc...and then tighten the jamb nut, to "squish" the O-ring also locking the 90 from "spinning" around as you attach the swivel end of the hose to the 90. No sealants, loctite, or teflon tape are needed on "JIC" or O-ring fittings...and don't overtighten them...usually about 180degrees with a wrench past finger tight...check for leaks prior to getting too far from home...
run the hose, away from moving parts, electrically conductive junk (like batteries, glow plug relay, starter relays, etc) ..and just route the hose up through the cowl toward the windshield...for short term testing purposes, we just lay the gauge up under a windsheild wiper, and go drive...testing it just like I describes previously...chip in the highest setting, floor the truck, etc....
If you can maintain 2800+ psi of ICP, then any injector 250cc's and under will perform exceptionally well.
If you can maintain 2400psi then that's not bad, not great either.
2200psi is mediocre, and full performance from any injector will not be achieved with that HPOP, though power WILL go up with nearly any injector, driveability (excessive smoke) might be an issue.
If you cannot maintain 1900psi, you might seriously consider an aftermarket dual HPOP system, or our Gen3 HPOP. Nearly any larger injector is going to make the truck feel sluggish, and smoke excessively.
Old Nov 6, 2007 | 05:39 PM
PAVEMENTMAN
Someone Told Me It Could Be Valve Cover Gaskets. When They Get Hot They Short Out, Is This True.??? How Low On Oil Does It Have To Be To Do This.????
Old Nov 6, 2007 | 05:50 PM
Action4478's Avatar
Action4478
That can be verified by looking , or unplugging ( at the valve covers) the injectors at the time it is acting up...The side that makes the most difference in the way it runs , is the good side....
Old Nov 6, 2007 | 05:51 PM
Action4478's Avatar
Action4478
Do you have access to a scanner?...
Old Nov 6, 2007 | 08:05 PM
PAVEMENTMAN
Sounds Like A Cam
I Dont Have Access To A Scanner. So Were Do You Pull These Plugs Out At. And Do I Do It While The Truck Is Running Or Off.
Old Nov 6, 2007 | 08:06 PM
PAVEMENTMAN
So Is It The Injectors Or The Valve Cover Gaskets.
Old Nov 6, 2007 | 08:31 PM
  #28
Action4478's Avatar
Action4478
While the engine is running.....Could be either...Find out which side..
marks500
43
Jan 23, 2011 09:13 PM
Sarge261
Sep 15, 2009 08:20 PM
JRSF150
2004 - 2008 F150
Dec 20, 2004 07:17 PM
Offroadingman
Sep 28, 2003 11:26 PM
