Number dummy please help!
Old Nov 4, 2007 | 01:14 PM
drof46's Avatar
drof46
I was in the process of taking the oil pan off of my 352. Have a dizzy rod that looks like it twisted off. Anyway, while I was down there I saw some casting numbers on the block. Grabbed my book and got a little excited. I may be wrong but want to verify before I get too excited.
Block= C5AE-A
Intake= C5AE9425B
Cylinder Heads= C4AE 6090C
Origianl truck tag=F10DK648837
The truck tag shows its suppose to have a 352 with 172 net HP
The engine looks like each piece has been removed and painted. Block and intake is blue and all the other small pieces were painted red. So I thought it may have been rebuilt by someone. Anyhow it still has a 2V carb.
Let me know what you come up with.
Thanks,
Old Nov 4, 2007 | 07:51 PM
drof46's Avatar
drof46
OK I grabbed a spare distributor and found out that rod is removable so I guess thats what I was seeing down in the hole. Wish I could edit my post now so the whole site doesn't see what a dummy I am, lol. Oh well you live and learn.
Still need help on those numbers however.
Thanks
Old Nov 4, 2007 | 08:23 PM
gangstakr's Avatar
gangstakr
Thanks
To late Dohhh!!
That's how we learn.
Old Nov 5, 2007 | 09:59 AM
Mike G's Avatar
Mike G
Well the C5ae-a block shows as a 390, so it appears that perhaps someone may have swapped in a short block under the standard 65 352cu heads and manifold. Are you currently tearing down the motor? If not, have you checked the stroke travel to see what the internals may reveal?
--Mike
Old Nov 5, 2007 | 11:57 AM
drof46's Avatar
drof46
I have not checked piston travel yet. I will likly take it apart a little. When I thought it was just a 352 I was going to get it started regardless of condition. If its a 390 I will proceed with a little more caution and clean it up a little. Last tag on the rear shows 1989 so it probably needs a good inspection. Did get it to turn freely with the starter.
thanks
Old Nov 5, 2007 | 01:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/72 FE F100/350 cylinder heads
C8AZ-6049-A .. Cylinder Head ~ 1966/67 ~ Without Valves ~ Use with Thermactor Emission.
C8AZ-6049-M .. Cylinder Head ~ 1965/72 ~ Without Valves ~ Without T/E.
Ford replaced the 1965/67 352 cylinder heads with the 360/390 cylinder heads, which carry the 1968 part numbers.
The only real difference is the smog manifold holes used in 1966/67, and they can be plugged with: 8-C6AZ-6052-A.
1965/72 352/360/390's as used in F100/350's all use the same 2V intake manifold. Ford didn't offer an optional 4V carb on F100/350 390 engines till 1973.
Nick-1973-ford
15
Dec 10, 2016 05:03 PM
asmith6
24
Aug 21, 2016 04:27 AM
ID Scrounger
May 21, 2016 10:33 PM
blisstruck
Dec 19, 2009 11:44 AM
65f100_352
Aug 3, 2007 12:34 AM
