windows
Old Nov 3, 2007 | 11:48 PM
hjoe's Avatar
hjoe
windows
does anyone know a manufacturer that makes automotive windows need some custom windows for my 79 crewcab
Old Nov 4, 2007 | 12:09 AM
RNOVRIT's Avatar
RNOVRIT
Just out of curiousity, what about the glass do you need to be "custom"? The glass in the rear doors is the same as the front. The only thing differrent is the part of the mount attached to the bottom of the glass. The track section of the mount on the glass on the rear doors is slightly farther forward compared to the front glass.
Old Nov 4, 2007 | 12:37 AM
hjoe's Avatar
hjoe
windows
that i have added 12 inches to the rear door and to the cab made it a bigger crew cab now i need to make rear windows for it
Old Nov 4, 2007 | 12:43 AM
RNOVRIT's Avatar
RNOVRIT
Cool! The side windows are just tempered glass. The windshield is the only laminated piece of glass. You might be able to bring an old piece of glass and a template to a glass shop and have one ordered.
Old Nov 4, 2007 | 12:58 AM
hjoe's Avatar
hjoe
ill have to try that i didnt know if thay had to make a template or what
Old Nov 4, 2007 | 02:56 AM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Wow...you got bigger doors in the rear of your crew? I think it time for some pics in your gallery.
Old Nov 4, 2007 | 11:02 AM
Mil1ion's Avatar
Mil1ion
Conatct any rod shop in your locale.
Custom glass is made all the time for them
Old Nov 4, 2007 | 11:06 AM
RNOVRIT's Avatar
RNOVRIT
Bring them the old pieces of glass so that they can get the curve of the glass right. Bring a cardboard template of the exact size you want the new glass and all should be good.....
To make the windows, basically they cut out your piece of glass and sand it into the final shape. Then heat it and give it the correct curve. Last, they put the glass through the tempering proccess. Once the glass is tempered, it can no longer be cut, sanded or modifiyed in any way. It will break....
Good luck and post some pics if you can. There are a lot of us with crewcabs on here that would like to see it.
...Rod
Old Nov 4, 2007 | 11:41 AM
Ford_Six's Avatar
Ford_Six
How can you do this to everybody here? You need to give pictures-
Old Nov 4, 2007 | 11:26 PM
hjoe's Avatar
hjoe
thanks for the overwhelming response i am in the process now of stretching the rear doors it is ALOT of work but will make this truck SO RARE that you will take a double lok when its done i cant wait to get it done going to have a cummins turbo when i get doors done a little more so it looks like a a cab with doors again i will get some pics posted...
centralNH
Apr 25, 2014 06:43 PM
superman0604
1978 - 1996 Big Bronco
May 24, 2004 04:44 PM
MGT351
Apr 5, 2004 05:54 AM
CrazyFordMan
Dec 4, 2003 09:04 PM
harvey
Jul 1, 2001 01:33 PM
