engine knock
Old Nov 4, 2007 | 04:36 PM
masterbeavis's Avatar
masterbeavis
Put in a quart of Marvel Mystery oil, (take a quart out first) then drive it for 100 mi. or so, then change your oil.
Old Nov 4, 2007 | 10:51 PM
f2501967's Avatar
f2501967
my freshly rebuilt 390 had a similar sound, then it went clack clack clack. i had the same symptoms, found out it was my rocker shaft assy, it was cracked and finally it went wild inside the valve cover. mine was cracked for a long time and it finally broke off. since then i replaced both rocker shaft assy. only cost me $200.00
just my 2 cents.
Old Nov 5, 2007 | 02:22 PM
ford5t6's Avatar
ford5t6
thanks
i'm going to look if the ignition is set right.
if that is the case and it still knocks then i wil pull the valvecover.
i have a set of pushrods valvesprings and rocker shaftassembly new so that could be fixed.
if that isn't the case i will look at the main bearings...
Old Nov 9, 2007 | 11:38 PM
UncleFudd's Avatar
UncleFudd
Hey ford5t6;
Howdy all.
Been a while and normally I just read and learn, but I couldn't resist making a suggestion before you get too crazy and begin tearing things apart
I believe that engine and trans combination had a real problem with throwout bearings and when they are going bad can sound ZACTLY like engine bearings.
Just a thought but worth while to eliminate before you spend serious money on things you may not need (yet).
Old Nov 10, 2007 | 11:06 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
UncleFudd, good to hear from ya now and then you should pop up your head up more often.
When the enginges knocking ground each plug lead at a time to see if you can locate the cylinder, also poke around with a mechanics stethoscope.
Old Nov 15, 2007 | 03:26 PM
PerfDistIgnition's Avatar
PerfDistIgnition
FTE Sponsor
Originally Posted by ford5t6
thanks
If you determine that your problem is ignition, a nice smooth advance curve will help.
If you decide to get a new distributor, consider our custom curved Duraspark Distributor built with our new Full Length Oil Impregnated Bronze Bushing. The full length bushing improves timing stability and spark scatter. If stock appearance is not an issue, take a look at our one piece D.U.I. Distributor. Whether you choose the Duraspark or the D.U.I., we curve each on a distributor machine based on your engine combination. Please see them at:
http://www.performancedistributors.c...istributor.htm
</O
Also, there is now an excellent installation article on the D.U.I. Distributor on the Ford-Trucks.com site at:
https://www.ford-trucks.com/article/idx/0/358/article/DUI_Ignition_Installation_In_A_Ford_351W_V8.html
__________________
FTE Sponsor
Performance Distributors
www.PerformanceDistributors.com
RedDevil460
53
Mar 29, 2014 08:16 PM
blue924.9
Jan 28, 2014 09:11 PM
wgfolsom
1983 - 2012 Ranger & B-Series
15
Mar 22, 2012 08:37 AM
viperrtblck
Jul 2, 2006 03:52 PM
Powerstrokedlariat
Oct 21, 2004 11:30 PM
