wet carpet
Old Nov 6, 2007 | 04:41 PM
big red c222's Avatar
big red c222
I just got back in I figured I try to find the condensate hose first and see what I could with it. It was murder. I don't know how I found it the first time like I said in the last post. I couldn't find it that way this time even with the computer removed. I got under and did end up finding it. It only sticks thru the fire wall maybe 1/2"-3/4". To get my hand up somewhat close I shoved my arm between the plastic wheel well and the cab. Coming thru that way I was able to shine the flash light right on it but still couldn't touch it. There is a bump out of the fire wall below it. It was enough to block the view and maybe give the water a place to get in. I made up a 1/4" pipe nipple with a street 90 on it. I was able to get it in but it was loose. I'm going to see if I can make something out of plastic that will fit tight. Dead center of the picture is tiny specs of white. That is the threads in the end of the hose
Old Nov 6, 2007 | 04:48 PM
big red c222
This is the nipple I made up. With needle nose in the end I was able to get it in the end of the hose. It was to loose. I was just using it to see what I needed and what would work.
simonwim
22
Nov 6, 2019 01:55 PM
Fordin
2015 - 2020 F150
Dec 12, 2015 05:00 AM
Evan_P
46
May 11, 2014 06:14 PM
BatteriesNotINCL
2004 - 2008 F150
Apr 15, 2007 06:05 PM
TallPaul
Aug 25, 2006 06:07 PM
