IS it worth getting??
Old Nov 1, 2007 | 04:21 PM
zss42002's Avatar
zss42002
i am looking to buy a new truck. i found a white amarillo 2006 6.0 with 25000 miles on it. they want 38900 for the truck. the truck is fully loaded all the options, ie. tow, sunroof heated mirrors ect. is the truck worth it?? i did oasis came up with this :
1.)Cust Comments: CUSTOMER STATES THAT DRIVER SIDE WINDOW DOES NOT WORK
PROPERLY.CHECK AND ADVISE.
Tech Comments: 1 VERIFY CUSTOMER CONCERN,PEROFRM PP TEST FOUND THAT
WINDOW MOTOR WAS NOT OPERATING PROPERLY.REPLACED WINDOW MOTOR INSTALL DOOR
PANEL.ALL WORKS FINE AT THIS TIME.
2.)Cust Comments: CUSTOMER REQUESTS PERFORM RECALL # 05E16
Tech Comments: 1 PERFORM RECALL # PERFORMED ENGINE CONTROL MODULE
RECALIBRATION.
3.)Cust Comments: E29 CUST STATES CHRCK ENGINE LIGHT ON ALL TIMES
Tech Comments: 20915 42 W PERFORMED 6.0L DIESEL DIAG TESTS. CODES P0404
P1408 P0299.PINPOINT AND REPLACED NEEDED EGR VALVE AND TURBO
ASSY.RETEST ROADTEST OK
4.)Cust Comments: GO7 CUST STATES DRIVERS SIDE POWER WINDOW INOP ALL TIMES
Tech Comments: 20915 W TECH 1945 VERIFIED CONCERN REMOVED DRIVERS DOOR
PANLE PERFORMED ELEC DIAG REPLACED WINDOW REGULATOR RETEST Q.I. 1945
5.)Cust Comments: LAMPS ARE SPECKLED
Tech Comments: SPIDER CRACKS ON HEADLIGHTS
6.)Cust Comments: KEYLESS ENTRY PAD FELL OUT OF DOOR REPAIR
Tech Comments: REMOVED L/F DOOR PANEL, FOUND KEYPAD INSIDE DOOR. RE
ROUTE HARNESS SO WINDOW DOESN'T CATCH HARNESS FOR KEYPAD & REASSEMBLE
DOOR. REPOSITION KEYPAD INTO DOOR, OK AT THIS TIME
is this truck a lemon b/c of #3?? has anyone had same problem and the truck is now fine after fixing?? just worried about dishing out some dogh and ending up with a lemon.
thank you
Old Nov 1, 2007 | 06:34 PM
rbaker6336's Avatar
rbaker6336
price seems a good bit high to me
Old Nov 1, 2007 | 06:45 PM
69cj's Avatar
69cj
I agree with rbaker about it seeming high. I paid 36,700 new for 05 lariet that had everything but sunroof.
Old Nov 1, 2007 | 07:20 PM
schmidt64's Avatar
schmidt64
I thought all the Amarillo trucks were yellow?
Old Nov 1, 2007 | 07:25 PM
CobraJay's Avatar
CobraJay
Price is way too high. Don't do it!! Take your time and look around. You will find a better deal.
Old Nov 1, 2007 | 07:47 PM
zss42002's Avatar
zss42002
i have been looking for about 2-3 months nothing has come up but this one. how about the problems it went back to ford for. has anyone had these problems. like number 3. is it anything to get worried about?? is this a lemon??
i was going to offer the guy 35000. does this sound reasonable?? what would you all pay??
Old Nov 1, 2007 | 07:51 PM
mastercaster's Avatar
mastercaster
agree with all above. you could have literally bought that truck new for not much more than that with good negotiating. tow package really doesn't add that much to the price. the heated mirrors were standard on xlt models and above. already having had the erg valve and turbo replaced, along with the other much smaller build quality issues, i wouldn't touch it for anything. take your time, and a good clean truck will present itself. for the price your talkinf for an '06, it would really have to be loaded to the gills, and never have been touched after final assembly for any reason, be it a window motor, turbo, or microscopic paint chip under the hood!! good luck on your hunt, and let us know what you find.
Old Nov 1, 2007 | 08:38 PM
killaford's Avatar
killaford
sounds like they got whatever monkey bizness was going on in the door fixed.
only thing that worries me is if the bad turbo was overboosting did it stress your gaskets/studs.
price is a little high but im sure you can deal on it if the truck is superclean.
if the heads are bad its stil on fords dime to 100K so its all good.
enjoy!
Old Nov 3, 2007 | 08:28 AM
zss42002's Avatar
zss42002
hey guys just saw the truck yesturday and i was in mint condition the exterior was awsome. i had it up on the lift a couple of things concerned me
1.) i saw a white substance under the whole engine under neath. i figured it to be dried up coolant. i dont know were it would be coming from. i dont think the heads b/c the truck was not smoking at all and no leaks while running were present.
2.) were the tranny was there was a black rectangular rubber piece and it seemed that oil was or did leak from there. some one told me it was the rear main seal but i really dont know.
3.) sounded like a small exhaust leak when i started her up cold but went away in about 3 min.
other than these things the truck is perfect. what is everyones opinion now that i gave a lil more detail?? thank you
Old Nov 3, 2007 | 01:43 PM
killaford's Avatar
killaford
this is what i was talking about headgaskets from the turbo overboosting. you dont see it come from the exhaust because it doesnt leak into the cylinder. what happens is cylinder pressure gets into the cooling system causing puking at the degas bottle.
your prolly gonna need warrenty work for puking but it shouldnt cost you more than $100 deductable.
seeing the truck is in fine shapes i think $31K is a safe bet.
Old Nov 3, 2007 | 01:57 PM
bismic's Avatar
bismic
The price is $7-8M too high. Offer them $31M. Is it from a dealer or an individual?
Just because there was no smoke and no "running leaks" does not mean that it isn't head gasket leak. The leaks will generally show when boost is high.
Also, rarely is it a rear main seal leak. More common to have a bed plate leak.
Old Nov 3, 2007 | 06:05 PM
zss42002's Avatar
zss42002
it i from a chevy dealer i offered them 35 and walked away. now what is a bed plate?? like i said it is leaking from the tranny and from a black recatangular piece of rubber. now how do i know if the trucks heads are blown and if they are fixed?? should ford of fixed it when the turbo went bad? the oasis does not say anything about head gaskets. now if i get the truck i am going to put arp head bolts and obiously new gaskets will this happen again?
Old Nov 3, 2007 | 06:21 PM
killaford's Avatar
killaford
if ford had fixed it, oasis would show it.
sounds like your set on the truck and unless the dealer is stupid he will take.
best thing for you to do is wait for the problem to manifest itself and takes it into a good ford dealer with a master diesel tech.
unless the truck is flagged no warrenty your golden and it might not even be the head gaskets. i would think if it was flagged oasis would show but that i dont know.
not likely to happen again if fixed right. what Bis was saying these things can leak from a lot of places and its not where it looks like its coming from but ford will fix that too.
Old Nov 3, 2007 | 06:44 PM
18vtx00's Avatar
18vtx00
Question
no, the turbo and egr are a very common repair where I am in new england-they just get coked and rusted up..normal warranty repair not a lemon at all. too high on the $$$ though..i thought all amarillos' we yella??
Old Nov 3, 2007 | 07:12 PM
zss42002's Avatar
zss42002
no not all a few in white. why would a truck be flagged no warentee? is there a forum for good diesel techs at ford dealers? or can anyone find out if they have a good diesel tech as a ford dealer? in otherwords i live in monroe connecticut and have about 7 ford dealers to choose from and dont know which one has good diesel techs. they all say they are better than the other. is there a forum for this anywere?
also the dealer did not take the deal at the time i offered. they want 37400. that is the lowest they are going and i told them the lowest i am going is 35000 with a 15000 trade in. only time will tell now if they take it or not but ya they are stupid if they dont but these dealers a stupid.
