Rear Differential leak?
Old Nov 1, 2007 | 08:06 AM
NeXtras's Avatar
NeXtras
I was looking under my truck the other day and i notice my differential was damp from what appears to be the gear lube... is this normal? Truck still seems to run fine
Old Nov 1, 2007 | 08:27 AM
netscaner's Avatar
netscaner
No, it's not normal, but not rare either.
Does it look like it's coming from a leaky pinion seal (where the driveshaft connects) or from the rear cover.
If it's just the rear cover it shouldn't be a big deal, but if it's coming from the pinion shaft seal it means at least the removal of the pinion nut and flange which requires some high torque work on reassembly.
There are some threads that you may be able to use as a how too, but I don't remember the key words needed for the search.
Old Nov 1, 2007 | 08:43 AM
NeXtras's Avatar
NeXtras
bootom of the dif a the cover.. i know they get somewhat moist
Old Nov 1, 2007 | 09:05 AM
Skandocious's Avatar
Skandocious
If its ONLY on the diff cover then the last person that did the gear oil change didn't seal up the cover very well. If the leak isn't very much you can probably just wait until your next change and give it a real good bead with some RTV before you bolt her back on. Just make sure to keep an eye on the oil level in the diff, you don't want it getting too low or your gears are going to start heating up.
Old Nov 1, 2007 | 09:13 AM
Skandocious
Whoops, wrong thread.... That was wierd...
Old Nov 1, 2007 | 09:16 AM
TheRoadVirus's Avatar
TheRoadVirus
I'm not sure if it would be the same for a '95, but I know that on my '90 it has a flat filter stock and the box wouldn't come close to fitting a filter that big.
Also; if it's just the diff cover I've had the same problem a couple times. And seeing as a shop did it before it was leaking I went back and had them re-do it. Only to have it seep again. I was worried about low fluid but I was there when they removed it to fix it and it was still very ok fluid wise. Now it's doing it again and I don't worry about it because it never leaves any puddles or anything and I don't drive it too much.
Old Nov 1, 2007 | 10:03 AM
NeXtras's Avatar
NeXtras
mine leaves no puddles either. and I was the last to do the oil change on them and i liberaly used RTV lol.. im not toooo worried about it, just double checking a little, i know its fairly common for a read dif to seep
Old Nov 1, 2007 | 10:12 AM
Skandocious
With a proper RTV seal there is no reason for it to leak. Even if the mating face is gouged the RTV works to fill the pits and create a leak proof seal. When using the RTV on the differential, it should be applied liberally all the way around the perimeter of the mating surface AND in a full circle around around every bolt hole, like this:
Also, be sure that what you're seeing is actually seepage through the RTV. I know on my differential that it APPEARS wet from the stain of the fluid when it was drained by the shop that did my gears. Unless cleaned, this stain will continue to look like relatively fresh fluid for a long time.
bigdog194
Dec 1, 2010 03:56 PM
stewartfan
2004 - 2008 F150
Sep 22, 2009 07:58 PM
twheat
Dec 2, 2003 07:50 AM
