VIN # Help
Old Nov 28, 2003 | 06:50 PM
twheat's Avatar
twheat
VIN # Help
Does the VIN # tell what differential my truck has?
The book I have lists different lubs for the different differentials, but I don't know which differential I have. Can some one post the VIN # code for the differential on a '93 F250 Diesel 4WD, 5 speed, or how I can identify what differential lub I need . Thanks
Old Nov 28, 2003 | 07:12 PM
bilder12's Avatar
bilder12
Try looking on the door post sticker and compare the numbers to the book listings. If previous owners did not change the differentials, the numbers should coincide and you can determine the lube you need.
Old Nov 30, 2003 | 09:10 AM
pnose's Avatar
pnose
Post the axle code off the door post sticker and we can tell you what was orignally there.
Old Nov 30, 2003 | 04:36 PM
twheat's Avatar
twheat
Thanks for the replys. The axle code is C9.
I've spent some time under the truck looking for additional #s. Among other #s there is a metal tag bolted to the differential cover that reads
E7 TW AA.
Also, I jacked up both rear wheels and when I turn one, they both turn in the same direction, does this indicate positive traction?
Thanks again, this is a great site.
Old Dec 1, 2003 | 02:32 PM
pnose's Avatar
pnose
C9=355 limited slip differential.Nice find!
Old Dec 2, 2003 | 07:50 AM
twheat's Avatar
twheat
Thank you pnose, thats what I needed to know about that.
I'll have more ??s no doubt.
Have a good day!
mrbigmark
Bronco II
Dec 3, 2009 06:34 AM
BroncOBX
2004 - 2008 F150
Aug 5, 2005 08:06 PM
3dr97150
1997 - 2003 F150
Jul 30, 2005 09:15 PM
ebduda
Oil & Lubrication
Feb 21, 2002 03:41 PM
70sFORDnut
Exhaust Systems
Sep 22, 2001 03:30 PM
