tach hookup
Old Nov 1, 2007 | 09:58 AM
subford's Avatar
subford
Originally Posted by 7.3 motorhome
it is a E 450 so this should be a Van Body also on that diagram of the pcm what does cto tap mean?
I have no idea.
A look up gives:
<dl><dt>CTO: </dt><dd>Acronym for coolant temperature override switch</dd></dl>But this can not be right for pin 19.
Old Nov 1, 2007 | 03:01 PM
Mil1ion's Avatar
Mil1ion
I'll print and post my copy.
My presumption that ford used the same harnesses with models like they did in yesteryear may have been at work here.
I found this in the manual though.
again for F-series.
KG3 CHECK POWER TO TACHOMETER
Disconnect large white instrument cluster harness connector.
Key on, engine off.
Measure voltage of Circuit 640 (R/Y) between Pin 6 on the large white instrument cluster harness connector and ground.
Key off.
Old Nov 1, 2007 | 03:52 PM
Franklin2's Avatar
Franklin2
again for F-series.
Key on, engine off.
Key off.
You are doing the same thing I did, assuming the F-series and the E-series are the same. I am now thinking they are not. I would also think all diesel pickups would have a tach standard? When I looked in the E-series manual, the cluster did not have a tach.
u.f.o
19
May 15, 2009 10:13 PM
dd4
Mar 6, 2008 09:01 PM
Quigoline
Aftermarket Products
Feb 13, 2008 05:02 PM
jqp00002
Apr 6, 2005 12:01 AM
