tach hookup
Old Oct 30, 2007 | 08:48 PM
7.3 motorhome's Avatar
7.3 motorhome
tach hookup
where would you hook up the tach on a 2001 e450 7.3 sending unit?
Old Oct 30, 2007 | 09:17 PM
Mil1ion's Avatar
Mil1ion
It should have a Tach signal hookup behind the dash in the wiring harness.
The other end either to the computer or some other spot.
I'll check my book
Old Oct 31, 2007 | 08:52 AM
7.3 motorhome
thanks any luck in the book
Old Oct 31, 2007 | 12:09 PM
Franklin2's Avatar
Franklin2
What are you trying to do? Hook up an aftermarket tach or get the original one fixed? The cluster I am looking at doesn't have a tach, but if it did, the tach would get it's signal from the PCM with a white/pink wire.
Old Oct 31, 2007 | 01:15 PM
7.3 motorhome
never had tach trying a aftermarket and where is the pcm.thanks
Old Oct 31, 2007 | 08:27 PM
Franklin2's Avatar
Franklin2
You might need to call the tach people and see if they make an adapter for the tach to wire in to your van. The PCM is the engine computer, and since it's a van, I will have to look up where it's at.
Old Oct 31, 2007 | 08:48 PM
subford's Avatar
subford
I could not find a wire for the tach coming from the PCM in the diagrams for the 2001 e450 7.3 van.
Old Oct 31, 2007 | 10:09 PM
Franklin2's Avatar
Franklin2
I could not find a tach option for a diesel van either, but I could not believe the factory did not have one, so I assumed I overlooked it. I did find how they did it for the trucks and expeditions with the one wire. If you could not find it either, maybe they didn't have a tach option for the vans?
So I might have made too many assumptions about being able to hook it to the PCM. If you can get with the tach people, they may have a way you can hook it to the alternator, or somewhere else with an adapter.
Old Oct 31, 2007 | 10:25 PM
Mil1ion's Avatar
Mil1ion
Power train control module connector #19 ..sends a signal to #5 on instrument cluster
Old Nov 1, 2007 | 08:38 AM
7.3 motorhome
so if I hooked up a tach lead to pcm 19 this would work or is it more accessable to find the #5 lead at the instrument cluster .thanks
Old Nov 1, 2007 | 08:49 AM
subford's Avatar
subford
Not sure about your information.
Old Nov 1, 2007 | 08:56 AM
7.3 motorhome
what I'm trying to say is where would the most accessable location be to hook up the tach lead is it on pin 19 at the pcm or can I find it at the wiring cluster ? thanks again
Old Nov 1, 2007 | 09:18 AM
subford's Avatar
subford
Pin 19 might give the information you need I am not 100% sure, this where it is on a 2001 7.3L Diesel Excursion. But for yours the information is what I posted above.
It says that the wire ends in the harness for your Van, you may be able to dig it out and use it if they used the same PCM as is in the 2001 7.3L Diesel Excursion.
I would say no the signal is not at pin 5 on your cluster, pin 5 on your cluster is a ground wire.
Let us know what you find and good luck.
Old Nov 1, 2007 | 09:29 AM
subford's Avatar
subford
I think I may have posted the wrong information, what I posed was for a 2001 Van with a 7.3L Diesel.
If yours is a F53 Motorhome with a 7.3L Diesel then you do not have a female pin #19 in your PCM Plug and may not have the male one at the PCM either.
Sorry
Old Nov 1, 2007 | 09:38 AM
7.3 motorhome
it is a E 450 so this should be a Van Body also on that diagram of the pcm what does cto tap mean?
