I found this number on my 460 heads when I removed the valve covers. At first I thought it may be a part # (meaning right or left) so I removed the other and found the same #. My question is what does this tell me about my heads?
if you mean the air injection pipe, then the 460 heads had them since 1970 at least maybe earlier. the DOVE heads i have from a 70 Lincoln had the ports in them.
all you need to do is tap them and install a plug.
