more about fuel pressure
Old Oct 16, 2002 | 08:28 PM
nastruck95's Avatar
nastruck95
i ahve a 95 F-150 with the I-6, what was all the talk before about increasing the fuel pressure to the stock injectors for the availability of horsepower. where and how is this done.
Old Oct 23, 2002 | 09:57 PM
Silver Streak's Avatar
Silver Streak
You need an adjustable fuel pressure regulator. Several companies make them for the EFI 300. Mine is a Crane and has served me well for about 3 years. Unfortunately, most have an upper limit of 60 psi which is only 1 psi above stock. This can be remedied by chucking the adjustment screw in a lathe and cutting down the head a little bit. On some models it is also possible to cut down the regulator where the screw threads in to allow more adjustment. Even with those tow mods I was only able to get about 65 psi out of the regulator. The better fix is to run larger injectors with less pressure, but that will likely cause a rich condition on the low end.
Old Oct 24, 2002 | 03:39 PM
Ford_Six's Avatar
Ford_Six
Old Oct 24, 2002 | 07:09 PM
nastruck95's Avatar
nastruck95
thank you for the help, by chance did you feel much of a difference in power though?
Old Oct 24, 2002 | 09:31 PM
Silver Streak
I really didn't get much power from the conversion. What I did get was better throttle response and about a 10-15% decrease in mileage. 2 years ago I did some back to back testing at the track with the stock injectors and 24 lb injectors. With the 24's I ran a 17.58 @ 73 and with the 14's I ran a 17.65 @ 72.??. I have since run a 17.48 with the 19's in much better air and with a limited slip rear end, and a 17.13 after replacing a PIP sensor that's been bad for a while. I've probably swapped injectors back and forth from stock to 19's to 24's and back a half dozen times and the stock ones have run right along with the larger injectors consistently. As for the mileage, my O2 sensor has about a 100k miles on it, 20 of which were with a set of 42lb injectors accidentally installed. In other words, the sensor is probably junk. I've got a new one to install, which might pick the mileage up considerably. Even if the mileage stayed the same I don't think the swap is worth while on a stock truck. By the time you by the regulator, injectors, etc. and do the swap you could have $150-200 invested if you do the work yourself. IMO there are better ways to spend the money, such as headers/exhaust or an MSD. I have headers, ram air, ignition and endless tuning and they were worth about a tenth in the 1/4 mile which is probably about 5 hp in this application. On a stock truck why bother with 5 hp when the same money can get you 20 spent elsewhere.
VONxRUBENxLA
17
Feb 16, 2023 10:21 AM
95PSDieselP
Jun 17, 2012 06:41 PM
95TBird
Aerostar
Jul 19, 2010 01:23 PM
Rebeltn
1978 - 1996 Big Bronco
16
Dec 14, 2008 01:24 PM
bigred66
Oct 5, 2007 12:16 PM
