Location of Fuel Pressure regulator on 97 Aerostar?
Which is great cause it means you need to pull the fuel rail to get to the screws. But look on the bright side, you can replace the intake gaskets, just make it a good day long job for some weekend, and you can replace the gaskets before they give you fits (someday they might start leaking and you will have the infamous and persistent lean codes.)
I've removed/installed the regulator before by using Allen head bits that I inserted from below, and turned it with a small ratcheting socket handle made for small bits to remove/replace the screws.
By the way, are you asking this because you think there might be a problem with your regulator?
Camp250
04-03-2012 09:10 AM
