EGR sensor question
Old Oct 29, 2007 | 02:29 PM
Fatstrat's Avatar
Fatstrat
EGR sensor question
How long should a EGR sensor last? I replaced the one on my '88 F-150 (w/4.9 straight 6, 5 sp OD, w/approx 300K miles,) about 2 years ago.
Old Oct 29, 2007 | 02:57 PM
Virto's Avatar
Virto
Ford says the entire EGR system should be cleaned and inspected every 15000 miles or 15 months, whichever comes first.
They can probably last longer than 2 years no problem, but that's not to say they always will. If you replace it again, make sure you use a Motorcraft part.
Old Oct 29, 2007 | 08:49 PM
Old_Paint's Avatar
Old_Paint
Umm, the one on my '92 is the same one that was on the truck when I bought it in November 1992. My guess is, at least 15 years. The ONLY sensor I've replaced was a MAP sensor, and even the original still works. I was chasing problems by throwing parts at mine because that's all I had time to do. I finally got smart and bought some instruments to help me work smart, not work hard.
As for cleaning the EGR every 15K? Umm, 154K and counting. NEVER been cleaned.
Old Oct 29, 2007 | 08:57 PM
Old_Paint's Avatar
Old_Paint
Oops, sorry for the double. IE stuck it's head in the dirt for a few minutes.
Old Nov 1, 2007 | 02:40 PM
Fatstrat's Avatar
Fatstrat
How does one clean the EGR? My engine has about 300K miles. Perhaps it needs it more often?
Old Nov 1, 2007 | 03:45 PM
TheRoadVirus's Avatar
TheRoadVirus
This is sort of an on topic question.. does the egr get it's gases from the thermactor system? If I remove and plug the thermactor system do I have to block off the egr?
Old Nov 1, 2007 | 04:11 PM
subford's Avatar
subford
No it gets it's gases from the from the intake manifold.
And No to the second question also.
Old Nov 1, 2007 | 04:23 PM
TheRoadVirus
Cool, thanks a bunch.
Old Nov 4, 2007 | 03:30 PM
Fatstrat's Avatar
Fatstrat
Back to the top.
Old Nov 4, 2007 | 04:43 PM
danr1's Avatar
danr1
http://autorepair.about.com/od/gener...l/bldef165.htm
mango379
Jan 16, 2013 01:50 PM
losmojica
Escape & Escape Hybrid
Mar 14, 2007 07:49 PM
JCastellaw
Jan 16, 2004 11:35 AM
